Need help removing dash
Old Jun 21, 2006 | 10:47 PM
Enersis's Avatar
Enersis
Default Need help removing dash
Everying out but the dash and head light lever, the top of the dash near thw windsheild feels like tis being held on, but i dont know whats holding it, and i cant figure out how to get the plastic *** off the headlight switch
please help, need to have it off, and put back on by the time i leave for work in the morning
Old Jun 21, 2006 | 10:50 PM
71-Triple Blk's Avatar
71-Triple Blk
I bought a 73 dash at Bloomington this past weekend - the front of the dash pad has several metal clips that look to clamp around a flange. It looks like a tug on it would release it.
Old Jun 22, 2006 | 12:33 AM
slowup's Avatar
slowup
Default lol
welcome to hell,
Old Jun 22, 2006 | 08:06 AM
jdp6000's Avatar
jdp6000
You need to reach up under and get at the headlight switch. There is a pin that needs to be pushed in as you pull out on the ****..
Jim
Old Jun 22, 2006 | 08:14 AM
Duke94's Avatar
Duke94
What year Vette? Dashes are different
Old Jun 22, 2006 | 08:20 AM
11Jake's Avatar
11Jake
I just removed mine this past weekend. I have an 80 so I am not sure this will help. The headlight **** is pressed on (really tight). I had to clamp the rod close to the **** and pry it off with a screw driver pushing against the vice grips. The dash has two push in clips at the top. One is above the speedmeter/tach. cluster and the other is above the glove box.
I hope this helps!
Old Jun 22, 2006 | 08:47 AM
68vertible's Avatar
68vertible
Not sure what year you have, but in the Dr. Rebuild catalog it says the same switch fits 68-77, then 78-82 are different. Then when you look at the **** in the catalog, all C3 years say 'rod and ****' so I gotta think they all come out pretty much the same.
On my 68, the **** and shaft come out of the switch housing by pushing on a small pin that is on the switch housing itself. To install the ****, you push the **** and rod assembly through the dash into the switch assembly. A barb on the end of the rod locks into the spring loaded pin. The pin is inline with where the shaft of the **** assembly goes in and maybe 1/4 to 1/2 inch down the body of the switch housing.
To release the ****/rod, pull the **** out so the switch is in the on position. Then push the pin on the side of the switch in to disengage the barb and pull the rod/**** assembly out. It's been a year or so since I was in there so I'm trying visualize how it was but hopefully you've got the idea. Good luck.
Old Jun 22, 2006 | 08:49 AM
70vert's Avatar
70vert
Banned Scam/Spammer
On my '70, it's like jdp6000 says.
ESC3's Avatar
ESC3
I hope this helps!
You did it WRONG!If you pushed the **** in then pushed the release button on the back the whole shaft,**** and all would have slid right out.
Old Jun 22, 2006 | 11:28 AM
Kilroy1024's Avatar
Kilroy1024
Push the button down (red circle).
Then pull the ****.
NO tools required.
Old Jun 22, 2006 | 12:02 PM
Enersis's Avatar
Enersis
Then pull the ****.
NO tools required.
pictures are best for stupid poeple likeme, thank you guys for yourhelp dash is off, and new dash cover is clued to the old dash, and working on fixing the rust leaks i have
Old Jun 22, 2006 | 02:22 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I hope this helps!
If you would have checked the forum first, you would have learned the proper proceedure for that operation.
To Need help removing dash
