Some Torque Converter Questions...
Old Jun 22, 2006 | 01:29 AM
JustinD's Avatar
JustinD
Default Some Torque Converter Questions...
I need to get a converter. My motor makes most of its power above 3500. (About 400-425 horse.) So what would be a good stall converter for my application. Oh by the way it is a turbo 350.
Old Jun 22, 2006 | 06:47 AM
J. Swisher's Avatar
J. Swisher
Gear ratio of the rear-end would help with input.
Old Jun 22, 2006 | 07:32 AM
ajrothm's Avatar
ajrothm
2800-3200, behind a decent small block that will give you around 3600-3800 of flash stall. That would be a good one for a daily driver. BUT if you are only going to run 3.08s, its gonna be kinda loose driving around town. Very streetable still bet a little loose. You will have to give it more gas to take off and your rpms will be 2000-2200 every where you go at light cruise. With a 3.55-3.70 it will be a little tighter but still flash good.
If you are just wanting all out acceleration, you can get you a 3500 stall, that will get you a 4000-4200 flash and thats gonna launch you really well. Once again, gearing and torque all play a role in TQ converter stall speed and looseness.
With any stall, you need a GOOD tranny cooler and ET Street tires or DOT stickies of some sort. Don't waste your time on regular radials.
Old Jun 22, 2006 | 12:12 PM
JustinD's Avatar
JustinD
I was thinking 3.73 or 4.11. So I can't run my stock tires? Why is that will they just break loose?
Old Jun 22, 2006 | 02:44 PM
gkull's Avatar
gkull
You need to buy a high end converter that is very efficient. I have driven around with as high as 3800 stall.
Good converters under no load level ground at 70 mph going down the freeway only have 200-300 rpm more that full lockup converters.
Vigilanty, Protorq, Art Carr, hughs.
3000 rpm is very doable in the 9.5 or 10 inch models for our heavy Vettes
I never really had very much traction even with 285/40/17 Z-rated. For the street they are okay. at the track I always used slicks with my little 355 ci motors
Old Jun 22, 2006 | 02:51 PM
Little Mouse's Avatar
Little Mouse
Default how much
gkull how much are high end converters in cost??
Old Jun 22, 2006 | 04:27 PM
gkull's Avatar
gkull
http://www.converter.com/vigilante.htm I'd guess around $700
http://www.artcarr.com/storm.cfm?fun...ProductID=7120 $763
I had failures with the sub $500 even furnace brazed blah blah blah converters. I shattered a sprag and it wasted the tranny also. My last converter was $1140 and worth every penny of it. over 4 years of trouble free use. I could do line lock burnouts with wheel speed of 90 mph to heat up my slicks and never give it a thought. Manual shifting at 7500 rpm and never let off the gas. or down shifting coming into a turn and the rear wheel would kick out because of going to fast for the gear. Not a big deal.
That cheap junk B&M or TCI just blew apart the first time I hammered it. I got so sick of stuff dying the first time out testing. It's the same thing for trannys. I got tired of changing them out under warranty and just went and bought one of the best.
Old Jun 22, 2006 | 04:38 PM
Little Mouse
Default Expensive
Sounds like Justind has got himself into a big expense with his big
camed 350, turbo 350 auto, 308 rear end.
Old Jun 22, 2006 | 04:49 PM
jerome1979's Avatar
jerome1979
you will use your corvette for?
- street only
- street and strip
- strip only
your th350 is stock?
nb: if you don't have an OD and you use street only or street and strip! remeber that you munt keep stall speed under RPM engine for crusing speed!
i make simple:
3500 RPM for 60MPH (60MPH imagine that is your crusing speed so max legal speed)--> stall converter UNDER 3500RPM because under stall speed a converter make a lot of heat
My set up:
ZZ430 (430fts.lbs @4000 and 430hp @5800)
3.55 rear axle
th350 with B&M transkit (rebuild home made)
2000rpm stall speed converter (B&M holeshot)
225/70/15 tiers (4 corner so rear and front)
great for street and 1or to week end on strip a year
(can hear tiers scream in passing 2to3)
Hope this help!
Old Jun 22, 2006 | 05:01 PM
holley505's Avatar
holley505
Sooo TRUE... I HATE TCI (Total Crap Industries)
I am running a 3000 stall non-locking 10 converter... FROM HUGHES. These are up in quaility over the TCI and B&M
Old Jun 22, 2006 | 05:18 PM
ajrothm's Avatar
ajrothm
For the quality per dollar, Hughes is pretty good. TCI and B&M converters are junk. They have less stall then advertised and usually blow up. Years ago I ran a BOSS HOGG stall from Alabama. It was your typical local speed shop special and was $150. It was a 2500rpm. It worked so well that when I built a stronger motor, I bought one of their 2800-3200 10" converters for $250. That converter lasted for years and the car would 60' 1.60s with a 3.42 gear. I would probably not recommend them but.. I did have good luck with em. TCI street fighter was junk as was the B&M hole shot.
Art Car, Trans King, Vigilante, Yank, Continental, COAN are all top quality and efficient converters but they are all $600+
For $300-350 you can get a 10" Hughes, around 3000 stall. I have not used one but they make quality stuff. I just bought a 12" Hughes 2500 converter for my dads 70' Nova.
Whatever you get, make sure its a 10", not a 12" that is just re-bladed and re-brazed.
Old Jun 22, 2006 | 05:23 PM
ajrothm's Avatar
ajrothm
As for your tires, you will need atleast drag radials..No street radial(like a BFG radial TA or Michelin)is going to hook up if you leave hard on the converter. Just get you some Nitto DR 555s, they hook pretty decent and give about 10k miles of use. I have them on my 99 TA.
Old Jun 22, 2006 | 08:27 PM
C3 Stroker's Avatar
C3 Stroker
The converter I use is an Art Carr 10" Super Torque. (Cost me around $600.00). This was custom built for my application: 2900 stall, flashes to about 4100-4200 RPM, and is very efficient (as efficient as most 11" converters). I've found it well worth the money. Before you decide on any converter, though, the stall speed will depend on.....
1. Vehicle weight
2. Rear gear ratio (decide on this BEFORE getting converter)
3. Camshaft characteristics- duration, rpm power band
4. Engine HP and peak torque RPM
This is the info needed that I was asked before mine was built as well as car use (street-strip). Good luck
To Some Torque Converter Questions...
