Ac/heater Blower Motor
Old Jun 22, 2006 | 08:34 AM
fdevole's Avatar
fdevole
Default Ac/heater Blower Motor
I just replaced the what needed to be replaced on AC and started charging (134a) and found out that the blower motor would not work. I checked the fuse it was OK I have ordered a new relay. My question is is there any where else I need to look for a problem? stupid me ----- this is on a 78
Old Jun 22, 2006 | 09:35 AM
SIXFOOTER's Avatar
SIXFOOTER
nothing stupid about it, get a book on that specific year car, shop manual. Good Stuff in there
Old Jun 22, 2006 | 09:42 AM
...Roger...'s Avatar
...Roger...
Is your blower motor grounded?Has its own seperate ground.Did you check motor by jumper direct?12 volts to terminal
Old Jun 22, 2006 | 09:43 AM
...Roger...
Old Jun 22, 2006 | 09:52 AM
fdevole's Avatar
fdevole
I have three books on specific year and all of them tell you how to change a blower motor,but nothing on trouble shooting electrical.
Old Jun 22, 2006 | 09:55 AM
flynhi's Avatar
flynhi
Poor ground or failed speed selector switch on the console are often the culprits.
Old Jun 22, 2006 | 10:24 AM
chevylit's Avatar
chevylit
On My 79 the hot wire had some corrision at the motor terminal,
cleaned it and has worked fine ever since. Kinda hard to get to the
terminal on the motor but whats not hard to do on one of these
puppies ?
Old Jun 22, 2006 | 10:36 AM
...Roger...
The ground terminal is special---the screw that holds it on must go through the metal case---the other screws go into fiberglass--the ground screw is usually silver and others are black---also if you had your starter off make sure you put that black wire with large turm.to ground
To Ac/heater Blower Motor
