Mechanical Advance Distributor Timing
Old Jun 23, 2006 | 11:31 PM
cruz-n69's Avatar
cruz-n69
Default Mechanical Advance Distributor Timing
OK, so I've seen a million threads describing how to set the timing for a vacuum advance distributor, but my 69 BB has an Accel dual point, mechanical advance distributor. It doesn't have the vacuum advance part. My question is this: What total timing should I shoot for at 3000 rpm or so. The vacuum advance guys say "36 degrees with the vacuum disconnected". I don't have vacuum, so what number should I look for?
Thanx,
-BC
Old Jun 23, 2006 | 11:53 PM
Fevre's Avatar
Fevre
Same as if you had vac adv, just follow the procedure and ignore the vac adv part of the instructions.
Old Jun 24, 2006 | 11:25 AM
cruz-n69's Avatar
cruz-n69
Default Sounds good
OK. Good deal, so I'll just set it for 36 degrees total timing at 3000 RPM and go for a ride!
Thanks for getting back to me.
-BC
To Mechanical Advance Distributor Timing
