High tourque mini starter
Old Jun 24, 2006 | 09:12 PM
bruced267's Avatar
bruced267
Default High tourque mini starter
I have a 1981 with a manual trans, when I got my dual exhuast done the pipe is touching the starter = hard starting when hot. So I got a mini starter, my question, do the manual and automatic get different mini starters? It doesnt seem to fit right around the sheet metal @ the bell housing? also the nose of the starter doesnt seem long enough to reach the fly wheel? any thoughts? Thanks in advance
Old Jun 24, 2006 | 09:38 PM
a1sensei's Avatar
a1sensei
I have an '81 automatic with headers that fried starters and went with a mini starter. I believe the flexplate on an auto and the flywheel on a manual have different numbers of teeth. I have read ads on some mini starters that specified the # of teeth it fits, but the one I bought said it fit both, and I think most do. The starter did not fit exactly to the sheet metal cover that goes over the torque converter, it had a small gap it left open that I fabricated a cover piece for. I don't know if this is similar to the problem you have or not, but the starter works great with no problems. God bless, Sensei
Old Jun 25, 2006 | 11:55 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Automatic flexplates and manual flywheels both exist in 153 and 168 tooth versions.
Old Jun 25, 2006 | 12:00 PM
mrvette's Avatar
mrvette
Anyone have any clue as to just what was on the minds of GM groups there when changing the starter bolt pattern from inline to staggered, and what in hell that brought to the table, and what in hell bother to change flywheel diameters....what in hell THAT brought to the table....
I can see a 2.8 family engine needed a smaller fly, and smaller starter, but....for a 302 UP engine??
GENE
Old Jun 25, 2006 | 12:01 PM
bruced267's Avatar
bruced267
would that make the nose of the starter longer or shorter? because it almost looks like it wont throw the gear out far enough? as for the fit around the sheet metal I think Sensi cleared that up? maybe Ill try again as the battery is dead!
Old Jun 25, 2006 | 01:35 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
I had a similar issue w/a mini starter in my 75. It didn't seem to fit into the lower flywheel sheetmetal cover correctly. It was only slightly off, but enough that the starter wouldn't sit completely flush even though the bolts would go in. I ended up removing the sheetmetal cover and ever so slightly enlarging the hole along w/adding a small notch where there was a raised area on the starter. After this, it fit fine w/no more issues.
Good Luck!
Old Jun 25, 2006 | 02:49 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Staggered = 168 tooth wheel
Straight = 153 tooth wheel
Old Jun 25, 2006 | 04:50 PM
mrvette's Avatar
mrvette
Batty, allthough that sounds straightforward enough, it's rong....
I just swapped my '72 original style vette stick shift flywheel to a buddy for his later one piece main seal flywheel, same outer diameter....only exception being the inner bolt pattern on the crank....
now my '72 had straight bolts, and 168 teeth....14 come odd inches diameter....
my '89 roller engine here has the later fly/flex plate but staggered bolts and still 168 tooth/fly/flex.....
go figger.....I dunno, still like to know what was on their minds....
GENE
Old Jun 25, 2006 | 05:22 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Ok, that's odd...I've always heard that the staggered design only went with the 168-tooth flywheel.
Old Jun 25, 2006 | 05:49 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Batman is spot on. The same is true of aftermarket and mini starters.
Old Jun 25, 2006 | 06:15 PM
mrvette's Avatar
mrvette
OK, not an issue as to who, i'ts what....
My buddy called, had a boat he got without engine, I was destroyed...so he get another SBC built, goes to install it, the old fly will not fit 'new' engine....old fly had a 2" even center hole, 6 bolts on crank, one locating pin, and 14.125 inch diameter...I would say 14.25 whatever....ok....
I measure the old fly from my original '72 muncie vette engine....it was exact to what he needed....same diameter....so my engine I know is staggered starter holes later model '89 truck block 4 factory bolt mains....355, so it takes the small hole fly, and has a ~14 inch diameter fly/flex....
so go figger...I have a smaller diameter chebby flexplate and i'ts got a 2" center hole....would bolt up to my 355 no sweat....but too small a diamter....I remember having to shell out some high bux back in '97 for a plate that would work, and i'ts larger diameter with smaller holes...and the block definately takes a staggered starter as I just had to change it after 8 years in Florida.....
somehow I don't think that seems to reconcile with the above opinion....
anyone??
GENE
To High tourque mini starter
