81 Carb problems
Old Jun 25, 2006 | 12:30 AM
Ben Taylor's Avatar
Ben Taylor
Default 81 Carb problems
My 81 has problems when it's cold (even on hot days) it will start, but it has a low idle and will die if I don't keep changing the throttle position, the check engine light is also on. Once it warms up everything works fine, no engine light.
I found that if I disconnect the 2 wire connector on the top of the carb, the car works fine all the time, but runs very rich and of course the engine light is always on.
What do I need to do to fix this? (I'm not ditching the computer and buying a different carb)
Old Jun 25, 2006 | 12:40 AM
SIXFOOTER's Avatar
SIXFOOTER
Usual culprits are vacume leaks. A good cleaning may help the carb situation, make sure the choke operating correctly. How many miles? When was the last tuneup? Any mods? The fact that it clears up after warming up pretty much tells you the carb and comouter are working so thats good.
Old Jun 25, 2006 | 01:17 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
This and the fact that disconecting the mixture adjustment solenoid makes it run fine but rich is exactly what's supposed to happen.
Old Jun 25, 2006 | 02:16 AM
Ben Taylor's Avatar
Ben Taylor
I have headers and a heated O2 sensor, but those have been in there for a few years. I just put in a similar to stock crate engine, and I have a hollow catalitic convertor right now. The carb, computer and trans have 125,000 miles on them. I've already replaced all my bad vacuum lines, I have a rebuild kit for the carb that I was planning on using someday, so it looks like I have a project for next weekend.
Old Jun 25, 2006 | 11:30 AM
CA-Legal-Vette
I wonder if the heated O2 sensor is the issue? How did you wire it up?
Until the engine is warmed up, I don't know if the computer looks for input from the O2 sensor, but I know that it's lloking for a rich condition. Would the heated sensor provide the same output as expected under these conditions? I don't know.
Do you have a correct and working sensor in the passenger side head? This is another switch that indicates that the engine is warm. Does your secondary fan (electric one) run all the time?
Old Jun 25, 2006 | 12:58 PM
a1sensei's Avatar
a1sensei
Sounds like a choke problem to me. I would advise you to e-mail Lars at v8fastcars@msn.com to get his choke set up paper before you start the rebuild. God bless, Sensei
Old Jun 25, 2006 | 01:33 PM
...Roger...'s Avatar
...Roger...
Did you read your computer codes?Your computer logged acode when the check engine light came on.Your computer is talking to you !!!
Old Jun 25, 2006 | 01:35 PM
Ben Taylor's Avatar
Ben Taylor
The O2 sensor just has a 3rd wire that's connected to 12v when the ignition is on. I put that in because the 2-wire O2 sensor wasn't getting hot enough with the headers, and it wouldn't pass smog. I took it by the local college's auto shop to test that everything was working, and tweaked it to have passing smog numbers. The passenger side head just has a switch for the secondary fan. I have a plug in there because I have dual electric fans with it's own sensor.
I did all this over 3 years ago, and it ran fine for 2 years with that setup.
Old Jun 25, 2006 | 01:52 PM
...Roger...
You are veering away from stock and that makes it tough.The MC solenoids are able to be checked with an OHM but I'm not the best on these.I'l look at the book and see if I can find something.Sixfooter has an 81 maybe he can tell you how to check it.Did you read your codes?
Old Jun 25, 2006 | 01:57 PM
Ben Taylor's Avatar
Ben Taylor
Here are my computer codes with descriptions, I don't think this tells us anything we don't already know.
12 - Normal Code
23 - Mixture Control solenoid is open or grounded
24 - Vehicle Speed Sensor. Disregard if set when drive wheels are not turning.
45 - Rich exhaust indicated by the O2 sensor.
Old Jun 25, 2006 | 01:58 PM
SIXFOOTER's Avatar
SIXFOOTER
Read the codes, it will tell you whats going on. Doesn't sound like the mods you have done would be a problem.
Make sure choke is good, The O2 sensor might be a problem until its warmed up.
Start with the codes and go from there
Old Jun 25, 2006 | 02:02 PM
...Roger...
12 - Normal Code
do you have a manual with code troubleshooting charts
Old Jun 25, 2006 | 02:03 PM
...Roger...
You might have to clear codes and start over
To 81 Carb problems
