A/c 1981
Old Jun 25, 2006 | 11:52 AM
bruced267's Avatar
bruced267
Default A/c 1981
I have slowly gathered up the parts to fix my A/C. new rec. drier,condensor,good used compressor,134a kit,and a orifice tube.Where is it and what does it do? Also I know the A/C controls need vacum where could I possibly find the old lines on the car?[firewall] am I missing anythig else? any thoughts?
Old Jun 25, 2006 | 12:50 PM
a1sensei's Avatar
a1sensei
An assembly manual should show you how everything went together originally (vacuum lines etc.). They can be picked up for around $25 and are a must have for working on your own car. The orfice tube is a metering device in the system. Since you are using 134a, throw away the $3 orfice tube and get a variable orfice valve (VOV) from NAPA for about $20. God bless, Sensei
P.S. Good used compressor? Don't bet on it!
Old Jun 25, 2006 | 01:35 PM
SIXFOOTER's Avatar
SIXFOOTER
The orafice tube is as A1 says a metering device. What it does is provide the pressure drop that creates the cooling effect need going into the condensor. When you pressurise a liquid or gas it heats up and when you run it thru a restriction like an orifice tube it shills off rapidly on the low pressure side. Weird but it works.
Old Jun 25, 2006 | 06:05 PM
bruced267's Avatar
bruced267
Can any one recomend a part# for a vov I looked a zip catalog they only list a vov for earlier models will one of those work? any way to check a used a/c compressor before its installed?
Old Jun 25, 2006 | 06:38 PM
SIXFOOTER's Avatar
SIXFOOTER
check this out
http://www.aircondition.com/vov/
To A/c 1981
