PS Pump Pully
Old Jun 25, 2006 | 03:05 PM
SIXFOOTER's Avatar
SIXFOOTER
Default PS Pump Pully
How the heck do ya get the bolt out of the PS Pump Pully?
Left or right hand threads?
Old Jun 25, 2006 | 03:36 PM
vetteaddic's Avatar
vetteaddic
I think its pressed on,you can rent the puller from the auto parts store.
Old Jun 25, 2006 | 03:55 PM
SIXFOOTER's Avatar
SIXFOOTER
I have a puller, but there is a allen head bolt in the front of the thing
Old Jun 25, 2006 | 04:08 PM
...Roger...'s Avatar
...Roger...
On the stock pump?that isnt right or on your new hydroboost?
Old Jun 25, 2006 | 04:25 PM
SIXFOOTER's Avatar
SIXFOOTER
this is actually on my 2000 Z71 pu. There is an allen head bolt of some kind in the end of the shaft on the front of the pully. I asumed it had to come out, then use a puller to get the pully off. Just found out that the puller I have doesn't fit either
Grrr...
Old Jun 25, 2006 | 09:08 PM
Sayfoo's Avatar
Sayfoo
sometimes the allen hole in the shaft is so that you can keep it from turning while unscrewing something
Old Jun 28, 2006 | 02:50 PM
SIXFOOTER's Avatar
SIXFOOTER
got it figured out. The pully is a tight press on, no bolt to hold it on. There are threads inside the shaft for a bolt to be used to push the pully back on with. I guess the allen hole in the end of the shaft is there to hold the thing still while something else inside gets tightned.
Thanks for the help
To PS Pump Pully
