81 Corvette MAP Sensor bypass???????
Old Jun 25, 2006 | 05:42 PM
jmchutchion's Avatar
jmchutchion
7th Gear
Default 81 Corvette MAP Sensor bypass???????
Is there a way to bypass the MAP sensor on my '81 vette? Its completely original with the exception of the smog pump belt being removed. Need help.......
Old Jun 25, 2006 | 08:15 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
considering the computer uses this sensor and the O2 sensor as the primary inputs to determine correct spark timing and fuel solenoid cycling, my guess is the only "bypass" would be a holley and vacuum distributor.
i had an intermittant problem with mine years ago and found that some dielectric grease in the electrical plug and a little lube on the vacuum port solved it. i was searching for a new one but never found a replacement. most people don't even know the '81 has one or where it's located, much less where to find a replacement
Old Jun 26, 2006 | 07:35 AM
markdtn's Avatar
markdtn
On my '86 Cutlass I used to get MAP codes. It turned out to be the carburetor was all gunked up. I would clean your carb and vacuum lines before giving up.
Old Jun 26, 2006 | 09:51 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
This is definately a "fix" rather than "band-aid" situation. Your E4ME(?) carb will run like crap without it. Don't be a Bubba...
Old Jun 26, 2006 | 11:09 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I agree.
ps: Clutchdust: Despite the fact that I occasionally run C4 wheels on my own car, yours is the first C3 I've seen that looks good with those wheels. Nice combo! (Not the best wording, but please take it as a compliment.)
Old Jun 26, 2006 | 11:19 PM
MsVetteMan's Avatar
MsVetteMan
Another reason why it's smart to ditch that POS computer........just ditch and enjoy whatever mods' you want.
Old Jun 27, 2006 | 03:14 AM
IronJen's Avatar
IronJen
Abby Normal
Old Jun 27, 2006 | 02:50 PM
Kalway's Avatar
Kalway
This thing?
Old Jun 27, 2006 | 03:16 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Ha. Real fuel injection is the only way to go.
Old Jun 27, 2006 | 03:39 PM
Kalway's Avatar
Kalway
Ruining a perfectly good car with a computer.
Old Jun 27, 2006 | 04:35 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Better than wasting fuel on technology that was outdated when LBJ was President.
Old Jun 27, 2006 | 05:04 PM
Kalway's Avatar
Kalway
If that's the case, the very engine we use was designed in 1955, so why aren't we using rochester mechanical fuel injection?
C3s were designed to use either a Holley or a q-jet. '82 is the exception.
Old Jun 27, 2006 | 06:11 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
By that logic, the C4 was designed to use the old cease-fire system. I guess they shouldn't have ever upgraded to the TPI, LT1, LT4 or, heaven forbid, the LT5. I guess everyone here who has upgraded a C3 to use EFI is wrong, too.
If you want to go NCRS, install a carb. For performance and fuel economy, EFI is the way to go.
Old Jun 27, 2006 | 06:29 PM
Kalway's Avatar
Kalway
The C4 was designed with computers in mind.
To 81 Corvette MAP Sensor bypass???????
