Centerforce Clutch Question
Old Jun 25, 2006 | 09:31 PM
Higs's Avatar
Higs
Default Centerforce Clutch Question
Did your new Centerforce Clutch come with an alignment tool? Mine did not and kept me from intalling my engine this weekend.
Old Jun 25, 2006 | 09:52 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You can align one with a screwdriver just as easily. Just eyeball the disc edges around the pressure plate as you align it all and tighten pressure plate.
JIM
Old Jun 25, 2006 | 09:58 PM
collectskulls's Avatar
collectskulls
NO my didnt either i sent them an email asking them if the 50 cent tool they could include with their 300 clutch was gonna bankrupt them? lol
I did get a polite reply though but still had to track down the tool lol
Old Jun 25, 2006 | 10:02 PM
Higs's Avatar
Higs
You nailed my thoughts exacly. Went to 2 auto parts houses today with no luck locating one. Clutch looks good but maybe this will help the next people get prepared.
Old Jun 25, 2006 | 10:03 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Wait until it slips. POS. I had a long bad expensive lesson with mine.
Old Jun 25, 2006 | 11:52 PM
...Roger...'s Avatar
...Roger...
I'm not sold on them either.
Old Jun 26, 2006 | 09:57 AM
68 NJConv 454's Avatar
68 NJConv 454
anyone have problems with the pivot ball joint that mounts to the bell housing? I've heard the centerforce clutches require you to modify/weld this pivot ball to get correct pivot motion of the clutch fork.
True? false?
Old Jun 26, 2006 | 11:05 AM
...Roger...
True? false?
Never heard of this- but could explain some things-I'll be watching for other posts
Old Jun 26, 2006 | 01:52 PM
CJS's Avatar
CJS
I put a CF II in my 57 Chevy. Works great! Easy pedal, chirps 2nd everytime. Got the tool at Advanced Auto for $2, agree this should come with the kit. Also, I removed my centrifugal weights, so it would install easier, Long story on that, but it works great without them.
Old Jun 26, 2006 | 05:02 PM
GTR1999's Avatar
GTR1999
Centerforce clutches have been a problem in corvettes for a while. Not as muc the clutch but the alignment of the linkage. I l know there are several guys here who had to remove the tranny a couple of times to correct the alignment by using a stock ball stud. The aftermarket adjustable ones will work once you get them dialed to the correct length and then either weld or loctite them from moving,as this also became a problem. Now on a 57 chevy they might just bolt in but corvettes always are a little different then anything else.
I decided not to deal with this and sold my NIB centerforce and bought a Hays. It bolted right in and has worked fine every since( 3 years now)
I think Lars had the spec to set the linkage at but I'd have to look through a lot of notes to find it.
Old Jun 26, 2006 | 07:06 PM
MikeC's Avatar
MikeC
I'm on my 2nd CF2 clutch and have never had issues with them.
I have used a tool to install the clutch either, it isn't hard without one. You can also make one out of the end of a broom handle and some tape.
Old Jun 26, 2006 | 08:00 PM
CJS's Avatar
CJS
I bought a Hays at the same time as my Centerforce. Both are made by Sachs in Brazil and are so marked right on the cover. They appeared to be made of the same or nearly the same parts. I measures the depth of both clutch pressure plates and they were the same.
Old Jul 4, 2006 | 10:51 AM
thevetterisbetter's Avatar
thevetterisbetter
Run away.
I'm looking at going into my CF II Dual Friction clutch again because of issues. I'm just going to replace it. Any recommendations?
Old Jul 4, 2006 | 11:16 AM
evalu8r's Avatar
evalu8r
I used the cfII with my 5 speed conversion behind a new 383 and yes it is 10.5". Absolutely no complaints.
Chris
To Centerforce Clutch Question
