Wiper Override Help!!!
Old Jun 26, 2006 | 08:15 AM
68 Blues's Avatar
68 Blues
Default Wiper Override Help!!!
Im working on a 68 BB car and need some help. I took the dash out of it and had the mechanical tach converted to electric. I put the dash back in the car and the next day the battery was dead. I knew then that it must have a voltage drain somewhere. After doing some checking, I found that as soon as the battery cable is connected (ignition off or on, it didn’t matter) the wiper override solenoid is activating. I pulled the gauge cluster back out to make sure I didn’t miss anything when I reinstalled it, and I didn’t. A little history about the car: My granddad bought it new in 68 and it was originally a small block car that was later converted to big block. About 5 years after he bought it it was stolen and a lot of the parts were stripped out of the car before it was left sitting on the side of the road. A lot of the dash was torn up, but from what I can tell none of the wires were cut.
I don’t know if something happened when it was stripped, or if there is some common problem that I don’t know about. Thanks for any input you might have!!!
Old Jun 26, 2006 | 12:32 PM
IDOXLR8's Avatar
IDOXLR8
Default 68 wiper problems
I will look at the wiring diagram but I don't think the wiper door vacuum control on the back of the distributor is the problem. The 68 wiper system is unique in its self being one year only (how many times you herd that!). The wiper motor relay under the console is one thing to look at and the wiper motor park switch is another. The one thing I remember was the system unlike the later designs has a powered with key and another cucuit power with the key on or off and thats the curcuit you need to look into. Do you have a wire diagram for a 68 Corvette? BTW I did see some mistakes in the shop manual like the over ride bulb with a black wire and some color mistakes on the wiper motor connections, AL.
Old Jun 26, 2006 | 12:38 PM
IDOXLR8's Avatar
IDOXLR8
One other thing, you called the wiper door vacuum control solenoid switch a over ride solenoid. This not for over ride only but a important part of the complete wiper system not just for the over ride, AL.
Old Jun 26, 2006 | 10:15 PM
68 Blues's Avatar
68 Blues
The part I am referring to is mounted to the back of the tach. It has two vacuum lines connected to it and a two wire flat plug. In my case the wires are brown and black that connect to it. I will get a wiring diagram, maybe I am calling this the wrong thing????
Old Jun 26, 2006 | 11:09 PM
THUNDERRODENT's Avatar
THUNDERRODENT
The tach solenoid should have two double wires running to it. A Double blue and a Double Yellow. The Blue wire runs from the Wiper motor connection to the solenoid. Then from the solenoid to the wiper switch, and then to the wiper motor relay. The yellow wire runs from the Center connection of the wiper motor, then to the solenoid, and then to the wiper motor relay.
All the solenoid is there for is to break the wire connection in case the wiper door is not open. The vacuum that feeds the soleniod comes from the wipre door arm switch under the cowl door.
I doubt this is your drain.
Have you tried to narrow the drain down? You can do this by testing the battery without the cables hooked up. See how many volts are in it. Then hook up the battery and see the volts in it. The difference is your draw.
Go to the fuse panel, pull a fuse and take a battery reading. Compare this to your draw. Do this one at a time and you will find out what draw is on what circuit.
It narrows it down for you.
Old Jun 27, 2006 | 08:16 AM
68 Blues's Avatar
68 Blues
I tracked the drain down by unhooking the ground cable on the battery and using a remote starter switch between the ground cable and the ground post on the battery. When ever the connection is made, this solenoid clicks immediately as if it has engaged. This is most definately the drain, with it unhooked it doesn't drain the battery. There are only two single wires going to this, one brown and one black.
Thanks!
Old Jun 27, 2006 | 08:49 AM
REDRED62's Avatar
REDRED62
Email me and I'll send you a schematic. Willcox@bellsouth.net
Old Jun 28, 2006 | 04:56 PM
IDOXLR8's Avatar
IDOXLR8
Default 68 Wiper System
Here's the sequence:
Turn wiper switch on
- Electric Vacuum relay [attached to back of Tach] engages and enables vacuum to wiper door system <<-- this could have issues from what you describe
- Wiper door opens
- When door is fully open, microswitch closes
- Wipers come on
Turn switch off
- Wipers park [and contact vacuum switch in passenger side cowl well]
- When wipers are fully parked and above vacuum switch is FULLY pressed, vacuum is enabled to wiper door actuator
- Microswitch OPENS disabling the wiper motor
- Wiper door closes
Make sure the ground to the wiper motor is solid - this can also intermittently prevent the wipers from coming on (but the door WILL open).
I saw this a wile back and may help, AL
Old Jun 28, 2006 | 05:32 PM
PRNDL's Avatar
PRNDL
Also you should have a wiper service override switch under the dash that will stop the wipers on the windshield. The owners manual states: CAUTION: Never leave the override switch in the "On" position since this will discharge the battery.
Yes, Chevy actually designed a battery drain into the car!
Old Jul 18, 2006 | 07:18 PM
Lucky68's Avatar
Lucky68
I have a 68 and a question... where is the 'microswitch' supposed to be, the one that the wiper door moves, and when switched it tells the wipers to go? The door opens fine for me but the wipers won't move.
Also another dumb question, but of the two switches under the dash, which one is the wiper overide? the one on the right I can turn, and the one on the left i can push... I just got the car, and never went over it with my father... Also, is the high beams the other switch under there? how do i turn those on?
Old Jul 19, 2006 | 08:47 AM
IDOXLR8's Avatar
IDOXLR8
Not a dumb question at all! there shouild be three controls under your dash. Two (one to the left and one to the right) are vacuum conrols that open the wiper door and the other opens the head lights. This makes it so you can change out a head light with the head lights off and the other so you can chage out your wiper blades and the middle control (that turns) is a control for the wiper motor so after you pull the wiper door control to open the door you can work the switch to have the stop in a position that would make it possable to change the wiper blades. As far as the dimmer that would be on the extrem left corner of the drivers sidw floor under the carpet, tap your foot in the area and you will see, AL.
To Wiper Override Help!!!
