PCV question
Old Jun 26, 2006 | 09:00 PM
Erics Quick71's Avatar
Erics Quick71
Default PCV question
Hi
Just adding a PVC to CARB hose.
Seems easy enough.
Add the Grommet, PCV, clamp, hose, clamp to Carb.
Should I coat the pcv valve with anything before inserting it into the grommet? Same for any of the parts, hose to PCV?, hose to carb??
VERY NEW CAR OWNER-
THANKS AGAIN!
Old Jun 26, 2006 | 09:03 PM
a1sensei's Avatar
a1sensei
No, It'll get coated in oil on it's own. God bless, Sensei
Old Jun 26, 2006 | 09:04 PM
Erics Quick71
So Just shove it in and off I go.
Probably the easiest project I will ever have...
THANKS
Is there a special tool for clamps?
It has 2 prongs and 2 in the middle going the other direction.
I used a pair of pliers for one and had no problme-the one on the carb is a little more tight and hargder to get to.
Is there a trick or special pliers?
Old Jun 26, 2006 | 10:22 PM
Sayfoo's Avatar
Sayfoo
THANKS
Sometimes a pair of 90 degree needle nose pliers work well to squeeze the clamps.
To PCV question
