Tru-Flex Bumpers or Not??
Gave up today on stripping my front urathene bumper. Aside from it being wavey and prior repair work on it. I decieded to replace both front and rear bumpers. (Rear is as bad as the front.) Not sure I want to buy a set of 21 year old used bumpers from the local vette shop. New GM urathenes are out of site at 500.00 plus per. Vette gets new paint next week so it's kind of a priority at this point. So I'm thinkin about the so called Tru-Flex aftermarkets. Any input on this or experience with these replacements would be useful!! Thanks guys, L8TER, Paul.
I put a true-flex bumper cover on the front of my '73. The fit was as good as or better than the original urethane piece, but there was a very slight difference in the conformation. By that, I mean the way it was formed. To me, it seemed like it was just a bit more angular than the urethane. Don't get me wrong, the car looks great without all the waviness of the old piece, and my observation is purely subjective, but there is a slight difference. All in all, it was a vast inprovement and I'd do it again without hesitation. One suggestion: Get the stainless steel retainer kits for $30 apiece rather than trying to reuse the originals. It'll make your life so much easier and they'll never rust, of course. Mid America has them, as well as just about everybody else, I suppose.
Kinda thought the feedback would lean more to the positive side. I just can't see spending $$ on old used bumper covers that have to be srtipped and painted anyway, when they can be replaced with a suitable "quality" aftermarket part, that's brand new!! I'll let ya know how it goes, hopefully by the end of today!! Thanks, L8TER, Paul.
So, be informed, and prepared or you may be disappointed!
"Teach"
OK, after a nights sleep and now not being so cranky, I should add the positive side to a hard fiberglass bumper:
They are susposed to not crack over time like the original bumper covers do. Which I tend to believe, but with no experience.
They are not supposed to discolor your paint job a shade or two, I suppose due to color bleed through of the original black colored material the poly urethane bumpers were made of.
They have got to be alot easier to install than the originals because you dont have to worry about using the original long thin retaining strips.
I would tend to suspect that they would be easier to move around and fit up onto your car, but the flex of the poly urethane bumpes would allow for a greater difference in fit from car to car and make a nicer final fit, if your not into doing alot of work, like I will be doing.
The poly urethane bumer covers do cost about $200-250 more than a show special tru-flex price, so the savings could be applied to paying a body shop fitting and straightening out the bumper it is doesn't fit to your satisfaction.
then you break even on the price, but avoid the fit hassles, and reap the benefits of hard bumper as I have indicated above.
If more people indicate that 1/4" or so of misalignment is typical and everyone has to deal with this issue, (which I had never heard of such a lousy fit from an expensive product, especially touted as the best, that I find not acceptable) after weighing the pro's and con's, a hard front bumper, and maybe tru-flex then is the ticket. I bought a hard front bumper because I dont want future cracks from mother nature, and don't want paint discoloration.
I just don't anyone else to be disappointed and feel like I was the only that got the bumper that "was made on Friday afternoon or Monday morning!"
[Modified by 73 Teach's Pet, 8:42 AM 9/1/2001]
From what I have read and heard. a quarter inch difference in a corvette front end is a great fit.
Hope your removable rear window fits better.
Terry
I molded my bumpers on, worked out nice.
the bumper was way to long, but I had to cut, splice and reglass all down the sides to make a good fit before i glued it on and finished moulding it to the car. in the last month i havent been able to work on it, to finish the prepwork for primer.
but considering the way the front fit I would hope the rear should fit the same with a trueflex
Sounds like a real hassel!! I have decieded to go with the Tru-Flex. I sure hope they fit better than yours did!! Gonna order them on Tuesday. Should I get the fasteners that are recommended for them or should I try to use the ones off my old urethanes?? The car will be ready for paint by the end of next week so I'll have to hold it off at least till I get the bumpers. I'm sure the body shop will not be happy with that little delay :cry L8TER, Paul.
Whatever you do, I'd make sure that you can easily screw the nut on before starting to mount them; it's a real PITA if you have to pull them on and off for little stuff like that. Also, don't tighten down too much - just leave them snug!
good luck
