power brake vacuum
Old Jun 27, 2006 | 09:13 PM
painterman52's Avatar
painterman52
Default power brake vacuum
I`m switching from an edelbrock carb to a holley dp. There is no port for the power brake booster, where do I go with this line for vacuum?
Old Jun 27, 2006 | 09:19 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
You can use the direct tap that's in the intake, between the carb & dist.
Old Jun 27, 2006 | 09:21 PM
BarryK's Avatar
BarryK
it normally plugs into a full manifold vacuum source on the base of the carb. If the new Holley doesn't have this you can drill a hole directly in the intake itself and install a fitting to run the power brake booster off of I believe.
EDIT: rat beat me to it.......
Old Jun 27, 2006 | 09:26 PM
painterman52
Thanks, I was hoping it would be a simple fix.
To power brake vacuum
