Power Door Locks (80)
Old Aug 30, 2001 | 10:52 PM
Kloppy80's Avatar
Kloppy80
Default Power Door Locks (80)
My power door locks won't lock when I attempt to lock them. The drivers door will unlock, but not the passengers door. When I go to lock them, they both have movement in them, so I know their is power to them, but won't unlock. You have to push and pull hard to lock and unlock the passengers door manually. Any suggestions? :U
Old Aug 30, 2001 | 11:28 PM
wombvette's Avatar
wombvette
Default Re: Power Door Locks (Kloppy80)
Go into the door. Clean and oil the plunger shaft. Operate back and fourth repeatedly untill it loosens up. There is a dust boot that you will have to pull back to get to it.
Old Aug 30, 2001 | 11:36 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default Re: Power Door Locks (wombvette)
that is what I did for my 80... Pulled off door panel and clean and oiled all moving parts for the door locks. Works like new, now. I had the same problem. Would lock but never unlock. a
Old Aug 30, 2001 | 11:48 PM
Kloppy80's Avatar
Kloppy80
Default Re: Power Door Locks (Bluewasp)
Thanks wombvette and Bluewasp! Never thought that it could possilby be something so simple.
This forum never ceases to amaze me! I get more, better and quicker instructions on repairs, installations and modifications than I ever could paying $75 an hour! And it's free!
Kloppy :cheers:
Old Aug 31, 2001 | 08:54 AM
Vettesic's Avatar
Vettesic
Had the same problem with my 80 and got the same remedy through this Forum by its great members!! Gotta love this place!!
Old Aug 31, 2001 | 10:42 AM
terry82's Avatar
terry82
had the same problem in my 82. my electric solonoid was full of water.replaced solonid and boot.all ways check switch contacs for corrosion.replaced switch harness both doors.
Old Aug 31, 2001 | 08:26 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Power Door Locks (terry82)
The problem on my 1980 was coroded wire contacts in the door. Cleaned them and at the switches, and all works well.
To Power Door Locks (80)
