Put on headers, engine won't idle?
Old Jun 28, 2006 | 12:28 AM
Berserker78's Avatar
Berserker78
Default Put on headers, engine won't idle?
I put full length headers on this week, but now that they are hooked up to the exhaust, the engine is having trouble idling.
Once it starts up, if I rev up to about 1500, it will come back down to 850-950 and idle there as long as I keep the transmission in park or neutral, but once I put it in gear, it goes down to 500-550 and stumbles.
It is much hotter now than it has been any of the rest of the time I have had it here, but I would not expect that to make much of a difference. I replaced the original ramshorn manifolds, though the heat riser was frozen shut.
Does putting the headers on make that much of a difference to the tuning? If so, can anyone recommend a good book on tuning the quadrajets?
Old Jun 28, 2006 | 12:29 AM
JustinD's Avatar
JustinD
Did you double check to make sure you got all of your vacuum lines back on? When I put mine on I didn't have to mess with the carb or the timing, It was just like instant power boost. Just look it over and make sure everything is back on correctly.
Old Jun 28, 2006 | 12:43 AM
Berserker78
Skippy, I bet you got it. I pulled the heat riser, but did not plug the hose. I bet that is it!
Thanks man!
Old Jun 28, 2006 | 04:31 AM
Kalway's Avatar
Kalway
If you went to headers and open exhaust from stock exhaust, you'll probably need to richen up that carb.
Old Jun 28, 2006 | 10:35 AM
Terrordome's Avatar
Terrordome
I had the same problem when I installed headers on my BB. Would not idle or run with crap. I played with the tuning, took care of the vapor lock by installing a heat shield between the fuel line and the header, and finally had to have the carb re built and go up 2 sizes in the jets to compensate for the new flow. After a month of weekend work I finally got it to run like a top. It is going to be frustrating, but a recommened the book by Roe on how to service Quadrajets, and find a good mechanic that knows them if need be.
To Put on headers, engine won't idle?
