Alternator/Battery Question
Old Jun 28, 2006 | 02:50 PM
bronze68's Avatar
bronze68
Default Alternator/Battery Question
Noticed on my car that it doesn't seem to be charging properly at idle (lights a little dim, etc). The motor was just rebuilt a couple hundred miles and I'm guessing that the belts have just loosened a little. Any other theories or am I on the right track?
By the way, the car isn't a C3 (actually a 70 Challenger) but this forum is always the best to get feedback on mechanical issues.
Thanks!
Old Jun 28, 2006 | 02:55 PM
SIXFOOTER's Avatar
SIXFOOTER
There is an article about that on Madelectrical site
Old Jun 28, 2006 | 03:00 PM
marshrat99's Avatar
marshrat99
Thanks!
I'd first check to make sure all of the electrical connects are clean and tight. Check the ones at the altenator and the battery.
Old Jun 28, 2006 | 03:25 PM
bronze68's Avatar
bronze68
All the connections @ the alternator & battery are clean & tight. Just checked the belts. They seem a little loose. I'll tighten them a little later & see what happens.
Old Jun 28, 2006 | 03:30 PM
bronze68's Avatar
bronze68
Interesting quotes from the article:
"At low RPM, expect that early models of alternators often produced much less available output than more modern designs. And with many models of old alternators, electrical output at engine idle speed was not sufficient to support electrical demands."
"Drivers of old cars were accustomed to the lights dimming at idle, or the turn signals blinking slower–it was simply the result of low voltage when the alternator did not keep up. The older cars could get by with less than perfect performance."
Maybe its normal after all. Didn't notice it much on my other cars but this is my first Mopar. Although both my GM cars have more modern service replacement alternators while the Challenger is period correct.
Old Jun 28, 2006 | 03:32 PM
noonie's Avatar
noonie
I don't know if you just lookes or cleaned the connections, but clean looking ones can really be oxidized enough to prevent low amp charging.
If tightening your belts doesn't cure it, then your regulator isn't kicking in properly.
Old Jun 28, 2006 | 11:18 PM
SIXFOOTER's Avatar
SIXFOOTER
a new 3 wire unit might get you fixed up. Conversion isn't a big deal, only 2 new wires
Old Jun 29, 2006 | 01:05 AM
White79's Avatar
White79
Old Jun 29, 2006 | 08:15 AM
Paul L's Avatar
Paul L
I converted to an electronic voltage regulator and it helped quite a bit. About $12.00.
Old Jun 29, 2006 | 09:26 AM
bronze68's Avatar
bronze68
Thanks for all of the suggestions & help.
Old Jun 29, 2006 | 01:09 PM
Highhat's Avatar
Highhat
Also, other grounding problems elsewhere can effect the re-charge (ground at the starter/block, dashboard, etc)
To Alternator/Battery Question
