Derebery Performance
New Vortec, Hydraulic Roller, Heads, Cam and Intake Kit
$1,499.00
New hand worked Vortec Cylinder Heads with swirl polished valves. 2.02” Intake and 1.60” exhaust. This kit comes with your choice of aluminum dual plane air gap or non air gap intake manifolds. We have 2 cams for this kit. For torque applications we have a custom grind “RV” cam that makes 360HP and 430 Ft. Lbs on our 9.0:1 short block. Also available is our “400 HP” cam, Dur. 218/228 Lift. .502/.502. The kit also comes with everything you need to convert to a hydraulic roller set up, including lifters, pushrods, crab plates and lifter retainer plates. To top this kit off we include new 1.6 rocker arms, vortec valve covers with bolts, ARP head bolts, and all the necessary gaskets.
I emailed them and they replyed saying The only difference will be that you will have to use a tie bar type lifter and different length pushrod. If you used a crane lifter and pushrod the price goes up around $500. Is that all that is needed to convert to a hydrollic roller. This is the same company that makes the motors for year one so if anyone has any input let me know thanks
