LT1 fuel pump psi/ gpm?
Jun 29, 2006 | 09:09 PM
Anyone know what an LT1 fuel pump psi is and the gallons per hour it pumps out?
Jun 29, 2006 | 09:34 PM
Quote:
Not enough!
Jun 29, 2006 | 09:46 PM
55 gpm @ 90-95 psi...
according to the NAPA website below:
http://www.napaonline.com/masterpage...c+In-Tank+Type )
I pasted the data below in case the link doesn't work. I searched a 1994 Chevrolet Camaro 5.7 liter.
Electric In-Tank Type)
Item#: NFPP74131
Price: $225.00
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Usually ships in 24 hours.
Attributes:
Fuel Pump Tank Seal #:Included
Gallons Per Hour:55
Pressure Rating:90-95
Strainer Part Number:STS-7
Jun 29, 2006 | 10:13 PM
He is asking about the older LT1 not the fuel injected one.
Jun 30, 2006 | 06:14 AM
Where's all the LT1 owners......
Jun 30, 2006 | 06:17 AM
Quote:
Originally Posted by Gordonm
Not enough!
Oh brother...........
That's like asking how many times do you shim a starter...DOOH..
Jun 30, 2006 | 09:25 AM
Reaching REALLY deep into the gray matter and will pull a number out of my "dark recesses". I THINK that the fuel flow number is in the vicinity of 4-5 gpm.
Jun 30, 2006 | 10:01 AM
Quote:
I think the gray matter is losing it.
That would put a stock pump at 240 to 300 GPH. Most high performance mechanical pumps are in the range of 120 to 170 GPH.
Jun 30, 2006 | 10:34 AM
DUH! Obviously, I meant
gph , as in per hour and not per minute.
Gary
Jun 30, 2006 | 08:32 PM
Someone will come up with the answer, just back up to the top we go!
Jun 30, 2006 | 08:36 PM
well, I looked up a 1970 Vette with a 4 barrel Holley
And here's what THAT says:
(If we had an original GM part number it might help the search)
Item#: NFPM6120
Price: $28.99
Usually ships within 3-5 days.
Attributes:
Fitting Size(s):3/8"; 5/8"-18 UNF-2B
Gallons Per Hour:23
Pressure Rating:5.5 lb - 7 lb
http://www.napaonline.com/masterpage...echanical+Type )
Jul 1, 2006 | 09:53 AM
Item#: NFPM6120
Price: $28.99
Attributes:
Gallons Per Hour:23
Wow! That is pathetic GPH flow.
Jul 1, 2006 | 02:55 PM
Wow,
that is very low flow...............Thanks for that info...
c3 ,
corvette ,
engine ,
fuel ,
gallons ,
gph ,
gpm ,
lt1 ,
min ,
needed ,
psi ,
pump ,
required ,
stock
