Cleanign overspray off instument cluster?
Old Jun 30, 2006 | 12:02 AM
SharkByte's Avatar
SharkByte
Default Cleanign overspray off instument cluster?
I am changing the color of my interior from Camel to black. I got the new seats, carpet and door panels in and sprayed most of the platic pieces to match a long time ago but I finally got tired of having the tan dash and steering column today so i went ahead and masked those off and sprayed them today. Unfortunatly I did apparently a crappy job of masking off the instrument cluster and got a little bit of overspray on the clear plastic cover which kind of blacks out the right side of the speedo I'm not to worried about it because I'm goign to be replacing it anyways but does anyone know a way to clean it off so I can read the speedo until i get around to that part of the project? I'm afraid I'm goign to make it worse with most of the paint removers I've used before...
Old Jun 30, 2006 | 12:25 AM
Berserker78's Avatar
Berserker78
straight-razor?
Old Jun 30, 2006 | 12:33 AM
SharkByte's Avatar
SharkByte
I thought of that... was leaning towards a light brushing with steel wool but I'm afraid I'll scratch it up. Anything alcohol based will more then likely turn it white The bezzle is cracked and the lens is scratched anyways so I'm going to be replacing it but I didn't want to have to do it soon... lol
Old Jun 30, 2006 | 03:00 AM
blackbirdpilot's Avatar
blackbirdpilot
A little bit of mother wheel polish on supper soft cloth, like a diaper. A clean one!!
Dont rub to hard, may take little while depending on how thick, but should come off slowly.
I polish all our used dash lenses like this and they come out looking pretty nice. if there is no scraches and just dull I used Wenol Red. really gets rid of the white/cloudy haze
Old Jun 30, 2006 | 05:56 AM
ESC3's Avatar
ESC3
I have had good luck with a small amount of reducer on a rag.
Old Jun 30, 2006 | 06:12 AM
SharkByte's Avatar
SharkByte
I have a can of Mothers wheel polish in the garage was going to do my rims tomorrow I'll give the lens a go to and see how it works. Thanks
Old Jun 30, 2006 | 07:28 AM
UKPaul's Avatar
UKPaul
For getting paint overspray off of metal/plastic I use either Solvol Autosol (for metals) or, for something like that lens cover, Duraglit. Duraglit is wadding with a very fine abrasive in it & is used for polishing metals like brass. Any similar, fine abrasive, polish should do it. The only problem with Duraglit (or Brasso) is that it stinks!
:cheers
Old Jun 30, 2006 | 08:39 AM
Edzred72's Avatar
Edzred72
Originally Posted by UKPaul
I use either Solvol Autosol (for metals) :cheers
Autosol is sold by Eastwood, and is a very fine abrasive metal/plastic polish. Ad in catalog says "great for restoring plastic lenses" and IT IS!! Did my rear tail light lenses and they look new again.
Keep in mind...any compound/solvent you use on a clear plastic lens will make it clowdy. It will never be crystal clear again....
Eddie
Old Jun 30, 2006 | 09:45 AM
UKPaul's Avatar
UKPaul
Solvol is excellent on bare aluminium, especially if you polish it with the solvol on a piece of card (pref the glossy type as used in greetings cards).
If you do use solvol on plastic & get a cloudy finish then something like Duraglit/Brasso will bring it up clear again, but it'll take hours of polishing.
Old Jun 30, 2006 | 11:05 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
I hit my gauges with a chem. that really screwed them up. I replaced the lenses when I redone the console. I couldn't believe the difference it made.(they shine like new, now) You would be surprised how much the lenses deteriorate after 30 years. Next, I'm replacing the spedo and tach lenses (more expensive, tho) Larry
Old Jun 30, 2006 | 02:49 PM
sfallison's Avatar
sfallison
I got some dye on mine... I used mineral sprits to remove it.
Old Jul 1, 2006 | 11:08 AM
Ron71's Avatar
Ron71
A little 3M Finesse it 2 on a soft rag should do the trick as well.
Old Jul 1, 2006 | 12:01 PM
Lee80's Avatar
Lee80
I used Brasso. It took a while but was a safe way to go. It also will remove light scratches - just take your time.
Lee
To Cleanign overspray off instument cluster?
