Rear rotors...A.zone?
Old Jun 30, 2006 | 11:05 AM
jshug's Avatar
jshug
Default Rear rotors...A.zone?
Would you recommend Autozone,Napa or who for Brake Rotors????
Old Jun 30, 2006 | 11:25 AM
OldSchool's Avatar
OldSchool
Very happy with mine from Rock Auto.. And the price is right! 59.99
Steve
Old Jun 30, 2006 | 11:42 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
My local NAPA dealer hooked me up....
Old Jun 30, 2006 | 12:25 PM
vettedesk's Avatar
0vettedesk
Supporting Vendor
We can get you rotors for $35ea.
Old Jun 30, 2006 | 12:38 PM
JoeRags's Avatar
JoeRags
bought my fronts from Advanced Auto parts... they're imports.. and I have yet to mount them and check runout... just got the bolts in the other day.
they should have them for you.
Old Jul 1, 2006 | 11:11 AM
jimiscnc's Avatar
jimiscnc
Default run out
my understanding is that both front and rear 65-82 rotors are machined as an assembly rivited to the spindles.
Therefore, you could put a dead nuts parallel and perpendicular brand new rotor on an existant spindle and get run out!
I.E., the registration face on the spindles doesn't have to be good. It's corrected by machining as an assembly.
I've had success in the past with regular sissors and brass shim stock to indicate a rotor face in. indicate, mark take apart - place shim between rotor back face and spindle front face, bolt back together, indicate, mark again, re-shim, repeat until 0.000" indicator reading.
But, a brake shop capable of machining a rotor on a car or as an assembly would be a wonderful thing to know more about.
-85% Jimmy
Old Jul 1, 2006 | 11:50 AM
jshug's Avatar
jshug
What about this set...?
Price looks real good and there G.M.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Jul 1, 2006 | 12:30 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
-85% Jimmy
Most good brake shops should have an on-car lathe. Hunter makes several models that sell well.
Old Jul 1, 2006 | 03:59 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Bought a car set from NAPA. No rivet holes, ok for me. I think Impaid less that $150 for all four. No install problems, no vibrations.
Old Jul 1, 2006 | 08:36 PM
rponfick's Avatar
rponfick
I got a set from Muskegon Brake. Price cannot be beat. Rear rotors were right on with about .001 runout. Fronts were a little more work, at .003 and .005. But shimming with Coke can shims got them within spec.
Good luck. Ralph.
To Rear rotors...A.zone?
