Running rough under load
Old Jul 1, 2006 | 03:25 PM
the73vetteman's Avatar
the73vetteman
Default Running rough under load
Started up the L48 4spd this morning and she idled great, just like she always does. BUT, put her in to gear and she didn't want to know. It feels like there's a rev limiter at 1500. She will not go over that.
Is this timing? An advance problem? Any ideas?
John
Old Jul 1, 2006 | 05:25 PM
jerome1979's Avatar
jerome1979
perhaps a fuel problem!?
clug filter for exemple!
Old Jul 1, 2006 | 05:31 PM
the73vetteman
I'm running a Holley 650. With the air filter off, if I blip the throttle I see plenty of gas squirted in so I think I can discount fuel starvation. Let me know if there's a better way to check.
J
Old Jul 4, 2006 | 10:10 PM
the73vetteman
OK, took your advice and cleaned out the filters. (I use the brass powder metal filters that go in the inlets of my Holley.)
Lots a crud in there. Put it back together, reset the timing for 14BTDC (was at 12) and now it's running so sweet.....
Thank you for the tip. You saved me a lot of time and $$.
Wonder what will go wrong next.
To Running rough under load
