Fuel Tank Removal
Old Jul 1, 2006 | 06:23 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default Fuel Tank Removal
On my 73, I need to remove my fuel tank for general clean-up and to find a small fuel leak (that drips on one of my mufflers,..nice).
After eye-balling the job, it appears I may have to lower my exhaust (it's the original exhaust system) in order to make room to drop the tank.
Can someone confirm if the tank can or can't be dropped with the exhaust (mufflers) in place.
Advice welcome, and thanks!
Old Jul 1, 2006 | 06:27 PM
big_G's Avatar
big_G
I find it necessary to pull the mufflers.
Old Jul 1, 2006 | 06:37 PM
Duke94's Avatar
Duke94
I removed the mufflers as well, gives more room to work as you will need to disconnect a couple of hoses on the pass side. before you can drop it all the way down.
Old Jul 2, 2006 | 12:11 AM
Z-man's Avatar
Z-man
I don't know how you would get it out without removing the mufflers first...
Old Jul 2, 2006 | 11:27 AM
73, Dark Blue 454
That's what I thought,..thanks guys!
Old Jul 2, 2006 | 11:28 AM
PhotoVette1's Avatar
PhotoVette1
The gas tank clears chambered exhaust systems nicely.
Old Jul 2, 2006 | 11:31 AM
GUSTO14's Avatar
GUSTO14
Originally Posted by 73, Dark Blue 454
...Can someone confirm if the tank can or can't be dropped with the exhaust (mufflers) in place.
Yes it can be done without removing the mufflers.... but as others have mentioned it is definitely easier to do with them out of the way. It's been a few years since I replaced my tank, and I may have lowered the mufflers, but I did not remove them.
Good luck and be careful when you start removing the straps... After draining the fuel tank, I got a face full of gas when I started loosening them and had to quickly tighten them up to stem the flow... I then used rags to sop up the remaining gas in the tank. Removing the straps revealed major rust holes in the bottom of the tank, and the straps were doing a good job of masking them.
GUSTO
Old Jul 31, 2006 | 08:32 PM
roger55's Avatar
roger55
I just removed the gas tank in my '69.
Only removed one muffler and it was a snap.
I don't think you could do it without removing one of them.
To Fuel Tank Removal
