Miss Fire under heavy acceleration when warm
Heat from the engine bay tends to cause coils to cut out when they are going bad that they don't do when they are still at a cool temp.
engine not overheating, just....
well, turns out it WAS plug wires, and headers, and boots, and crap...
so I just spent 150 bux on a complete set of Jacobs ceramic plug boots and Accell shorty plugs....THAT finally killed the summer ragged as hell running problem....mind you in the mornings it was running fine, get it into closed loop and it fell apart....
THAT combined with one hell of a tip in stumble I am still playing with, was a stupid thing to cope with on a part time basis, what with so many other projects outside the car going on, and then other aspects of the vette also added in...so anyway...
PLUGS?WIRES...first suspect....BTW, my junk was NEW, not that it mattered much....
GENE
No doubt i'll get comments on this the same as I did in the C2 section telling me I'm nuts and that there is NO WAY this could be the problem, but it can be!
what kind of spark plugs are you running? If you are running standard spark plugs most of them now are a resistor spark plug. Try swapping out to a non-resistor spark plug.
Over the winter I did a lot of work on my '65. it includeing rebuilding the distributor, a new distr. cap and rotor, new spark plugs, new ignition wires, rebuilt the carb, and a lot more.
I ended up with a high rpm miss problem.
It was suggested by a good friend that is VERY knowledgable on motors to swap out my new AC R45 plugs that I just put in (and have been using the same type for years with no problem) for a non-resistor plug. Taking his advice I swapped to the NGK B4 non-resistor spark plugs and my miss went away immediately.
The theory behind his reasoning is this:
The original spark plugs on the car were non-resistor sparkplugs. Over the years the AC R45 changed to a resistor spark plug. It was never a problem but then I also changed to new spark plug wires.
It's possible that the higher suppression on the new wires in conjunction with the resistor spark plugs could cause just enough of a voltage drop to cause a missing problem.
He had developed the same problem and installing a non-resistor plug solved his problem.
I tried his advice and put in the non-resistor plugs and it solved my missing problem also.
it's at least something you may need to consider looking into if nothing else solves the problem for you.
My fried that had the same problem and suggested I try the nen-resistor plugs went thru EVERYTHING first including the coil and nothing worked until the non-resistor plugs so I tried that first.
Had the car out 3 or 4 times already since installing the new plugs and everything is perfect.
BTW, I would think a new coil would more easily mask the problem of a faulty plug rather than new plugs mask the problem of a faulty coil. If it's really the coil going bad, swapping to a different plugs wouldn't help - if there was no voltage or current for spark out of the coil, no sparkplug would be able to mask that problem, but possiibly a newer, stronger coil could overcome and push thru a spark on an "iffy" plug therefore masking that problem. Or so MY thinking would go........
Regardless, IF the problem comes back the coil would be next on my list to look at.
