stalling
Old Jul 2, 2006 | 01:10 PM
philbshelb's Avatar
philbshelb
Default stalling
i have a 73 l48 auto with a qjet. when driving around the engine sometimes wants to stall or cut out, it seems like a fuel problem because if i catch it in time and pump the gas it will run. i don't have the car that long and i am trying to get any bugs out. any suggestions on what to try first?
thanks a lot
Old Jul 2, 2006 | 04:47 PM
farkedup's Avatar
farkedup
at you at a stop or near a stop when it wants to stall? Mine was doing this and a bit of carb tuning fixed it.
If its while cruising then I'd say fuel pump! Might sputter a little from time to time while at cruising speed. Fuel pump is a quick swap.
Old Jul 2, 2006 | 04:55 PM
Bob Onit's Avatar
Bob Onit
I would test the fuel pressure first before I went and changed the fuel pump
Old Jul 2, 2006 | 05:14 PM
patto's Avatar
patto
Check the bowl levels. I have a Holley which did the same. Combination of heat and not enough fuel caused starvation. Check the issue on a hill, if it wants to stall this could be the problem.
Old Jul 2, 2006 | 08:12 PM
philbshelb's Avatar
philbshelb
it will do it at a stop but also while cruising around town
Old Jul 2, 2006 | 08:38 PM
Bob Onit's Avatar
Bob Onit
Is it the stock Carb, Quadrajet?
Old Jul 2, 2006 | 08:45 PM
philbshelb's Avatar
philbshelb
yes
Old Jul 2, 2006 | 08:55 PM
Bob Onit's Avatar
Bob Onit
Sorry, you stated it was a Quadrajet in your first post
It certainly does sounds like a fuel problem.
If the ignition is in good order, timing is set correctly, I would start with replacing the fuel filter, if that doesnt clear things up I would think about a rebuild on the QJ
Did this car sit for a long period of time?
Old Jul 2, 2006 | 09:06 PM
philbshelb's Avatar
philbshelb
i don't have a lot of history on the car but the previous owner for the last two years said it sat thru the winter but that was about it.thanks for trying to help i will try a fuel filter.
To stalling
