2 more Quadrajet questions
Old Jul 3, 2006 | 02:02 AM
Bob Onit's Avatar
Bob Onit
Default 2 more Quadrajet questions
Hey all!
Has anybody ever seen studs rather than bolts for the front (the long bolts) for a QJ?
The reason I ask is if I am going to be removing the air horn for tweaking I am leary of damaging the threads on my aluminum intake by constantly removing and installing the bolts. If so where can I purchase them?
Also, does anybody have a set of long bolts lying around that they can measure the length for me in case I need to hunt for the studs?
Second question is where can I purchase power pistons,rod hangers,and springs for a QJ
Bob
Old Jul 3, 2006 | 02:14 AM
KJones's Avatar
KJones
WOW... been working on these things since LONG before the Q-Jet arrived on GM cars and have never seen such a thing (studs for a Q-Jet). I have taken them on and off MANY times with no problem. With no disrespect intended I think your concern is misplaced. Just use care making sure you don't cross thread them..
Ken
Old Jul 3, 2006 | 06:13 AM
noonie's Avatar
noonie
But I've had to helicoil a lot of manifolds.
Old Jul 3, 2006 | 07:22 AM
comp's Avatar
comp
anti-seez on the threads
Old Jul 3, 2006 | 09:11 AM
Big Dan's Avatar
Big Dan
summit has ARP stud kit for QJ
Dan
Old Jul 3, 2006 | 10:08 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Agree,..no need for studs.
Also,..here's the place I use to purchase Q-Jet parts,..good people.
http://www.carburetion.com/
Old Jul 3, 2006 | 11:23 AM
PRNDL's Avatar
PRNDL
I thought it was fairly common to substitute studs for bolts on the Qjet, or any carb for that matter. It does reduce the chances of overtightening and stripping the threads. I did read on this forum about a carb stud falling into the engine and destroying the block.
vendor that sells carb parts... there are a couple. I don't have the link handy but they tend to have "carb" in the name. Used to be able to get some parts by part# from GM dealer, but that is getting harder and harder to do as they discontinue carrying the pieces.
Old Jul 3, 2006 | 12:07 PM
73, Dark Blue 454
Or,..you could go to your hardware store and purchase 5/16 course thread studs in grade 5. Cut to length, call it good. But most carb studs have course thread for the intake end, and fine thread for the nut (tightening) end.
But what was good enough for GM is good enough for me,..bolts. You're not gonna tighten it down enough to harm any threads in the intake. I don't know what the torque recommendation is, but it's not much.
Also, there are engine lift plates that mount to the carb pad that lift the engine,..and aluminum intakes survive and thrive.
Good luck.
Old Jul 3, 2006 | 01:16 PM
Bob Onit's Avatar
Bob Onit
Good luck.
Using bolts from a hardware store wont be the same as using studs. Studs arent threaded from one end to the other, theres an area where the threads stop, thats usually where it bottoms out in the manifold.
As far as "bieng good enough for GM" and "the lifting plates on the manifold" this is not a stock cast Iron manifold...Its aluminum.
The torque specs are 60-80 INCH lbs which isnt much at all.
Having studs installed assures that I wont be touching the threads on the intake at all while working on the carb.
I have had problems with aluminum threads on quite a few different parts over the years which I beleive is fairly common ...if it wasnt then HeliCoil would be out of business.
Thanks for the links to the sites guys!
Bob
To 2 more Quadrajet questions
