well I didn't change the pump,but when I took off the pressure hose from the pump,the whole bolt from the pump came out and the was 2 o-rings and one was pretty broken....I tried replacing it with a new one from the hardware store here,but it leaks from there a bit but no big deal.....
Based on this information, it sounds like it is time to replace your power steering pump.
It seems that mine is giving enough assistance. I takes both hand to turn when trying to park. It was better before I rebuilt the control valve, ram, pump, and box. All were done at the same time. Maybe its just the vavle in the pump, or maybe the pump is bad.
