Smog Pump-Does it Click?
Old Aug 31, 2001 | 08:30 PM
Paul L's Avatar
Paul L
Default Smog Pump-Does it Click?
I just replaced mine with a re-built because it was clicking when cold. Now the re-built is clicking when cold after less than 100 miles. Is this normal? The click is not constant but intermittent. Could this be the diverter valve doing what it is supposed to do?
Old Aug 31, 2001 | 08:49 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Smog Pump-Does it Click? (paul79)
mine does not click. The valve is a relief valve that opens when you decellerate.
Old Aug 31, 2001 | 08:52 PM
78Vette-SA's Avatar
78Vette-SA
No click here either. Mine is th eoriginal but I took it apart to clean it and replaced the gaskets. It makes a sort of funny noise when just spinning it freely by hand, but you shouldn't hear a clicking noise.
I assume you checked the vacumm line hooked to it?
Old Aug 31, 2001 | 10:38 PM
Paul L's Avatar
Paul L
Default Re: Smog Pump-Does it Click? (78Vette-SA)
Yes, all hook-up hoses are fine. I cannot believe that I got two bad re-builds in two years! The clicking goes away if I remove the smog pump belt. I think I will just live with the annoyance. At $90.00 a pop these pumps are not cheap.
To Smog Pump-Does it Click?
