69 Bigblock halfshaft size?
Old Jul 3, 2006 | 05:50 PM
Les's Avatar
Les
Default 69 Bigblock halfshaft size?
I'm about to tear into the back of the Vette to hunt down a vibration. In the process I've noticed that my half shafts appear to be 2 1/2" diameter. Is this the stock size for a 69 bigblock? They were freshened up several years ago and do have Spicer solid U-joints.
Since I should be running 500+ HP w/ my combo, would it be wise to upgrade to a pair of halfshafts with 3" diameter such as those offered by DragVette? I'll definitely be ordering the halfshaft loops from him anyway so I figured I'd get it all at the same time if I decide to upgrade. I do expect to hit the strip with some sticky tires once I get this all sorted out. Any opinions on this? Thanks guys.
Old Jul 3, 2006 | 10:21 PM
GS977's Avatar
GS977
i will be watching this because my 72 bigblock coupe will be making about the same power and i was wondering about what to do with the rear end. mine came with a 350 from chevrolet.
Old Jul 3, 2006 | 11:33 PM
b71vette's Avatar
b71vette
I would recommend going with the 3" halfshafts with the saftey loops also. The halfshafts from Dragvette come with regular solid spicer u-joints, but I would recommmend having Steve (Dragvette) swap out the u-joints for the Spicer Life Solid U-Joints, these are the same u-joints used in a lot of 4 x 4 so they are tough. If you have a local drive-shaft shop around you may can get the same joints swapped out cheaper, but the shop probably will not be able to beat the price on the Dragvette half-shafts, least that was the case for me. Have them re-balanced too after the swap. I wouldn't recommend doing this yourself unless you have flange support, this keeps you from bending the flange when pressing out the u-joint, don't ask me how I know. Bough a $100 press to DIY and ended up having to replace the bent flanges and paying a shop to do it.
Old Jul 4, 2006 | 12:24 AM
Les's Avatar
Les
B71vette,
Good info, thanks. I'll call him tomorrow & order per your advice. Just out of curiosity were the halfshafts you replaced 2 1/2" or is my car a freak for having that size?
Old Jul 4, 2006 | 12:37 AM
b71vette's Avatar
b71vette
2 1/2" was OEM standard up thru 78 or 79 I believe
To 69 Bigblock halfshaft size?
