For some reason tonight my turnsignals dont want to work. After Ive been moving for a couple of miles they will start working, then a few minutes later they stop... After i pulled into the garage tonight I shut her off, started her and tried the signals, they wouldnt work, then i let the hood slam shut and they started working... Can anyone give me any ideas where to start?? :smash:
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Re: Turn signal problem (Rich80)
I just replaced a bulb on my 70 front left tun signal and the light would not work correctly. I could go out and tap on the light and it would work. I eventually found out after taking the bulb out and checking it with a meter that the element was broken, causing the light to not working correct. Installed new bulb and all is correct.
Now I just have to figure out how to get my brake lights to work again.
Go to: http://www.corvettefaq.com and look under Suspension and Steering. There is a paper on turn signal switch diagnosis. If the other suggestions don't work, it may be a big help.
Loose Flasher!! round blue flasher that plugs into the top right side of the fuse box was ready to fall out...... Thanks guys for all the help!!! Rich.....
