Not really thrilled with this
Old Jul 6, 2006 | 05:59 PM
panchop's Avatar
panchop
Default Not really thrilled with this
These are a set of Aerospace Components hubs / brakes on my 75 spindles with a set of Weld prostar wheels. I relize they don't depend on the hub to be centered but still ...
Old Jul 6, 2006 | 06:09 PM
JoeRags's Avatar
JoeRags
try taking the picture from straight on... tough to tell from that angle.
Old Jul 6, 2006 | 06:13 PM
litevette's Avatar
litevette
Yeah, looks like the rotor sits way high compared to the rim. What gives?
Old Jul 6, 2006 | 06:23 PM
panchop's Avatar
panchop
Just seems like an excessive amount of space sround the hub.
Old Jul 6, 2006 | 06:36 PM
Zimo's Avatar
Zimo
I wouldn't worry too much about that. Pretty much all american car hubs are 'lug-centric", while most european cars are "hub-centric". As long as it's drawn in evenly & there's no runout or wobble it won't be an issue. FYI, before installing any wheel, always make sure both mounting surfaces are clean. If you are installing an aluminum wheel to a steel hub, put some copper anti-sieze between the mating surfaces to reduce corrision & a stuck wheel.
Always use a torque wrench & tighten in a cross-pattern.
Old Jul 6, 2006 | 07:49 PM
Mild2Wild's Avatar
Mild2Wild
My rims fit the same.Just put a dust cap on and cover it up.Or if it really bothers you ,you can sell your car like I am,,or am I keeping the car?What day is it,,
To Not really thrilled with this
