distributor bushings
Old Jul 6, 2006 | 11:34 PM
jlaw68's Avatar
jlaw68
Default distributor bushings
inside the distributor there are 2 black flat bushings (or whatever they are called) that the advance weights sit on. does anyone know where i can get a couple and what their technical name is. and does anyone have a pic of the top of the distributor with the cap and rotor off i need to know which way to reinstall the weights and center plate.
thanks
johnny
o yea its a 78 L48 with HEI
Old Jul 7, 2006 | 12:05 AM
...Roger...'s Avatar
...Roger...
Those are called "buttons,weight base" to be exact.GM#1957329-same button for tach cross shaft on tach drive distributors.
Old Jul 7, 2006 | 10:04 AM
jlaw68's Avatar
jlaw68
thank you much, now i can wrap up this intake and distributor job.
To distributor bushings
