can't find 9 leaf 2 1/2 inch spring. is there any reason i can't use a 2 1/4 7 leaf or does any one no where i can buy the 9 leaf. have already checked eklers and vette brake. no luck
Mid America has them, as does Volunteer Vette. I would go with volunteer before I would go with mid america, they are more knowledgeable and have MUCH better customer service.
zip has them listed for $170. I had the hardest time trying to find replacement liners for mine because someone replaced my spring and diff carrier with the HD one, but they are out there.
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
VBP has the nine leaf, so does a place called elmers auto ( corvette junk yard near me where i got mine
I know where you can get one. Me! I have one with 1500 miles on it on my car that is being replaced with a fiberglass one. It is the 9 leaf 2 1/2 " spring. It is attached to a 3:55 with a 2 1/2" stock cover with 1500 miles on a complete rebuild. It is perfect, No noise, correct backlash, No excessive play anywhere, no leaks, no issues . Might be a good time to upgrade the rear end Spring $100 with bolts and bushings. $800 for rear end pumpkin, spring, cover and spring bushings and bolts. I just built a HD 4:11 for mine. I am rebuilding the whole car. Going with a 383 W/ nitrous, TKO 600 and the 4:11 You could sell your pumpkin and cover and recover most of your investment. Will throw in the IRS traction bar too!
