Broken bleeder plug
Old Jul 8, 2006 | 01:25 PM
red7d7's Avatar
red7d7
Default Broken bleeder plug
After reassembleing my rear end. Once I got to the point of bleeding the brakes the inside bleeder plug on the LR caliper broke off. My question is should I drill it out and if so will there be a replacement plug to fit the hole? Or is there another way of getting the plug out?
Old Jul 8, 2006 | 01:32 PM
1BAD80's Avatar
1BAD80
Try some heat and a easy out.
Any auto parts store should have the bleeder.
Drilling is a last step to do.
Old Jul 8, 2006 | 01:38 PM
red7d7's Avatar
red7d7
I thought of the heat, but it snapped off flush with the caliper. I see nothing to grab hold of to turn it out.
Old Jul 8, 2006 | 06:26 PM
Rockn-Roll's Avatar
Rockn-Roll
Check at a local hardware store for an eazy-out...it's like a drill bit with reverse threads that should be able to grab onto the bleeder and back it out. An alternative would be to turn the rear caliper upside down and use the bleeder threads on the bottom of the calipers...OK it's more like an alternate reality. Try the easy-outs. There are 5/16" bleeders available, but if it comes to that you might as well get a rebuilt caliper.
Old Jul 8, 2006 | 07:36 PM
Chris Farrer's Avatar
Chris Farrer
Plenty of WD40 and a reverse drill will pop the little sucker right out.
Old Jul 8, 2006 | 11:57 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i never had luck getting these out time for a new caliper i would think
To Broken bleeder plug
