Blue smoke
Old Jul 9, 2006 | 09:53 PM
Frankie too's Avatar
Frankie too
4th Gear
Default Blue smoke
I have 1979, 350, L82. The car looks as though it is leakining a little from thee valve covers at the rear.
When I start it up, a wiff of blue smoke appears then go away.
It only does it after it sits for awhile.
Any suggestion what might be the cause?
Old Jul 9, 2006 | 10:02 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
If oil is leaking from the valve cover onto the exhaust it will cause it to burn off when the exhaust heats up...is the smoke coming from under the hood? If this is what is happening, there should be significant visual evidence of the oil. R&R the valve covers and replace the gaskets. (BTW there are only two valve covers).
Old Jul 10, 2006 | 05:37 AM
Frankie too
4th Gear
I believe th smoke is coming from the exhaust on start up.
Old Jul 10, 2006 | 05:59 AM
RHD '68 L89's Avatar
RHD '68 L89
Frankie,
Sounds like valve stem seals are letting a bit of oil into the intake/exhaust. It is only noticable on start up when the oil has had time to accumulate.
Replace the seals and check the guides at the same time. If the guides are sloppy then it's time to do a valve job.
Be aware of the "while I'm at it I'll......" syndrome, you may end up with a big block in there.
Old Jul 10, 2006 | 08:28 AM
CheezMoe's Avatar
CheezMoe
If it is puffing out the exhuast I agree that the valve seals are the likely culprit. If you have good compression all around, you could probably change the seals with the heads on and solve the problem. If compression is down, RHD '68 L89 might just have point on the big block.
Old Jul 10, 2006 | 09:16 AM
Crash80's Avatar
Crash80
I went through this on my 80 as well and it turned out to be valve guide seals. Next thing I knew, there were new heads and a new cam in there, as well as true dual exhaust. It fixed the problem.
Old Jul 10, 2006 | 03:45 PM
Jims77L82's Avatar
Jims77L82
I too have this problem.How hard and expensive is it to replace the seal?Is it a do it yourself project?
Old Jul 10, 2006 | 03:50 PM
Ed Blue 03's Avatar
Ed Blue 03
It would be wise to do a compression test on the engine before replacing the valve guide seals.
Old Jul 10, 2006 | 05:35 PM
694speed350's Avatar
694speed350
I would do both. compression check and seal replacement. the blue smoke you see in your description is coming from bad valve seals or worn valve guides. the compression check will give you an idea of the piston rings and valve condition.
Old Jul 12, 2006 | 07:33 PM
Frankie too
4th Gear
Originally Posted by RHD '68 L89
Frankie,
Thank you very much. "specially the while I'm at it"
To Blue smoke
