Lots have done it, All of them say it is worth it. I know the 700 requires more mods than a 200 does. I am going with the 2004r because its almose a bolt in
OD trans install I used a 200-4R but it is similar to the 700. Things you will need:
1. new detent for the shifter
2. new cross member
3. shorten drive shaft
4. some method to attach TV cable to carb
5 lots of patients setting up the TV cable
Best mod to my car ever! Not only do you get an OD gear, but the torque converter locks up. Run low 3.55 or 3.7 gears with a high stall like a drag car, but OD with lockup like a autobahn cruiser.
Has anyone installed paddle shifters like the new C6 autos. I'd like something like that.
Requires the 6L80E transmission, which requires a computer.
