Final primer on...wet sand question
Old Jul 11, 2006 | 12:04 AM
White 68's Avatar
White 68
Default Final primer on...wet sand question
Finally had sometime to paint I,m getting close to base/clear ...I,m using PPG primer NCP 271 over a PPG DP epoxy sealer on bare fiberglass...What grit wetsand paper should I finish with before spraying my basecoat ....PPG DBU classic white
I,m at 320 and it looks pretty smooth is 600 needed for white ?
Thanks for suggestions
Heres some pictures from today
http://temp.corvetteforum.net/c3/sog...252005_004.jpg
http://temp.corvetteforum.net/c3/sog...252005_005.jpg
http://temp.corvetteforum.net/c3/sog...252005_009.jpg
http://temp.corvetteforum.net/c3/sog...252005_016.jpg
http://temp.corvetteforum.net/c3/sog...252005_018.jpg
http://temp.corvetteforum.net/c3/sog...252005_022.jpg
Old Jul 11, 2006 | 12:24 AM
Corz's Avatar
Corz
Cruise-In IV Veteran
I did 400 wet, but depending on how heavy you put the primer on, you might sand through it.
600 would be a safe bet, but it'll take you a bit longer to get it flat
Old Jul 11, 2006 | 07:32 AM
crazywelder's Avatar
crazywelder
Your project looks good. Don't take this the wrong way, but you should be using the manufacturer data sheet for every paint product you are using. The data sheet available at your store or from the manufacturer web site answers this question as well as compatibility, reduction, recoat, and dry times. For example some of today's paints can't sit for more than a week without being recoated. All the critical info you need to know is in these, because if someone gives you a wrong answer, you could be in big trouble. I've been using DBU a lot lately and 400-600 is fine. If you are not going to use a sealer before your topcoats, I would go to the finer side with 500-600. Now go get your data sheets for the DBU and the clear you plan to use. If you have enough DPLF leftover you can use it as a sealer.
Old Jul 11, 2006 | 09:01 AM
hwcoop's Avatar
hwcoop
Looks great!...
I would replace your plastic masking on the pipes with paper., After you spray the base coat, when you go to spray the clear its going to blow off any paint that is on the plastic....lots of little flakes of paint and crap all over the place
I learned the hard way on a Silverado
Old Jul 11, 2006 | 10:26 AM
rponfick's Avatar
rponfick
I see a gas water heater in the corner of your garage. I would be very careful painting in the garage. You have a large fan, but I am not sure that will solve the problem. At least turn off the water heaters pilot light when you are spraying.
Ralph.
Old Jul 11, 2006 | 01:45 PM
bondoboy's Avatar
bondoboy
For modern finishes 400-500 grit is fine. I have painted a lot of cars with single stage and base clear and 400 has never caused a problem. If you use too fine grit paper the paint won't stick as well. Paint adhesion is a mechanical bond. It sticks to the sanding scratches. If you go too fine, the scratches are too small for the paint to hold on to.
Old Jul 11, 2006 | 07:51 PM
White 68's Avatar
White 68
Thanks for the info guys ...Yes I had the hot water heater turned off during spraying ...
I have the p sheets , but don,t remember reading about how fine a paper to go down to ? I,ll have to re read ..
I will replace the plastic wrap with paper ...Great tip
To Final primer on...wet sand question
