1975 emmissions equiment help!!!
Old Sep 2, 2001 | 09:47 AM
ZD75blue's Avatar
ZD75blue
Default 1975 emmissions equiment help!!!
Hi all
I am piecing together the emmissions parts for the '75 and I would like to know where i could get the pipe assembly that goes down from the valve cover to the passenger side exhaust manifold? I cant find anything that besides manifold tubes.
Also how hard would it be to fabricate this pipe? looking at the assembly manual it appears it would be easy enough but I'm not sure what the pipe is made of/ what diameter it needs to be.
In my assembly manual it is on page 336 (bought from corvette central :( )
Thanks guys for your help
ZD :confused:
Old Sep 2, 2001 | 10:58 AM
KED74's Avatar
KED74
Default Re: 1975 emmissions equiment help!!! (ZD75blue)
No such thing.
WHAT I BELIEVE YOU ARE REFERRING TO is the pipe from the air cleaner to the valve cover, passenger side (you have same air cleaner assembly as I do-1974). At the back of AC unit. It takes the fumes down to the engine, recirculates them. Located right by auto tranny fill tube-if ya have the auto tranny.
That's a bit of a search.
BUT call J & D Corvette 800-VETTEJD, ask for Dennis, tell him Karl sent ya & you'll do fine.
J & D opened M-S, PST, Sat 8-1-2pm
Old Sep 2, 2001 | 11:06 AM
theandies's Avatar
theandies
A friend of mine just bought a 75 convertible and the pipe I think you are refurring to is the AIR pump pipe that goes from the AIR pump to the AIR tubes in the right hand exhaust manifold......Butch, if you could take a look at yours and help ZD75blue out that would be great. I bought a 71 so I could avoid any emmision problems . I beleive you can get these components from any of the usual catalogs but I would try to find one at a local parts store first. Might be alot cheaper. Butch found an AIR pump locally and If I remember right he bought it for $19.00 at O'Rilley's. I know it won't win any NCRS events but it did pass state inspection!!!
John
Old Sep 2, 2001 | 11:48 AM
petty44's Avatar
petty44
ZD, the pipe I thank you need is the injector pipe you can get at ZIP new 109.00 or recond. 60.00 you will also need the check valve, very important!!!!!! You can e-mail me at bushog44@earthlink.com if you have any questions. Also as John said I got a rebuilt air pump at Pep boys and it was 49.00 with a core. hope this helps you out. :cheers:
Old Sep 2, 2001 | 02:37 PM
ZD75blue's Avatar
ZD75blue
Default Re: 1975 emmissions equiment help!!! (petty44)
I bought the kit for the 75 from Corvette Central it turns out that it doenst have the injector pipe (that enters the passanger side exhaust pipe NOT the manifold tubes!)
I bought the exhaust system from ecklers that has the spot for the tube in the front y pipe now I need to get the pipe that goes to that
Man do I wish I could fiqure out how to post a picture that is mine hehe i can do the gif's just fine
ZD
Old Sep 2, 2001 | 03:29 PM
ZD75blue's Avatar
ZD75blue
how would you go about fabricating this line? Is it rubber or metal?
ZD
[Modified by ZD75blue, 2:30 PM 9/2/2001]
Old Sep 2, 2001 | 05:14 PM
Hershey's Avatar
Hershey
ZD, the tube is thin wall metal tubing and on mine it was welded into the exhaust pipe, passenger side. On the top end of this line is the check valve and it is connected to the air pump with a rubber hose. Mine is up in the attic, so I went up and double checked it for you (saving it for next owner, if ever). I'll bet one of the auto discount stores in your area has or can get it for you. Hershey :chevy
Old Sep 2, 2001 | 05:18 PM
ZD75blue's Avatar
ZD75blue
Default Re: 1975 emmissions equiment help!!! (hershey2@surfsouth.com)
thanks hershey
I'll check with autozone
With these cars I'm getting to where you check with the forum, then ecklers the zip :yesnod:
Thanks again guys
ZD
Old Sep 2, 2001 | 06:38 PM
theandies's Avatar
theandies
ZD
We are trying to help you with your emmisions AIR injection tube. Butch is going to try and take a picture of it on his 75. He says you can get the tube from ZIP. I'll post the picture as soon as he send it to me. He dosen't know how to post pics yet either. He is new to the Forum and my guess is that he will become as addicted as we are!!!!
:lol: :lol: :lol:
John
Old Sep 2, 2001 | 06:58 PM
theandies's Avatar
theandies
Default Re: 1975 emmissions equiment help!!! (theandies)
Here you go. This is out of ZIP. Sorry it is so blurry I tried to clear it up.
New is P/N EH-474 $109.00
Reconditioned P/N U-241 $60.00
I love spending other peoples money :lol: :lol:
Good luck
John
Old Sep 3, 2001 | 11:00 AM
ZD75blue's Avatar
ZD75blue
Thanks a bunch guys
so I'll need the two different part numbers? which is which?
ZD :confused:
Old Sep 3, 2001 | 11:02 AM
ZD75blue's Avatar
ZD75blue
whoops sorry just re read it and ! is reconditioned and the other is new
I guess I'll go new just because the rest of the kit is too
Thanks guys :yesnod:
ZD
To 1975 emmissions equiment help!!!
