'79 Rear Speakers
Old Jul 12, 2006 | 02:55 AM
Antnyd82's Avatar
Antnyd82
8th Gear
Default '79 Rear Speakers
Has anyone else here had a hard time replacing the original 6x9 rear speakers with new 6x9's? if so what did you do I can't seem to find a pair that will fit or mount correctly.
Thanks,
AntnyD
Old Jul 12, 2006 | 03:08 AM
SizzleChest's Avatar
SizzleChest
pioneer ts-929
Old Jul 12, 2006 | 08:11 AM
L8279's Avatar
L8279
Ecklers has the origanal style, the old ones had a square magnet for clearence. If you are upgrading your sounds system go with the pioneers $$$$$.
Any other speaker and you will have to cut clearence in the support bar that your shade mounts to.
Old Jul 12, 2006 | 08:22 AM
Rodbuster's Avatar
Rodbuster
Default Custom
I run a fab shop so I made some to replaced the old ones.I was thinking of making more just because it looks like there may be a market for them.
Old Jul 12, 2006 | 08:29 AM
Jims79's Avatar
Jims79
I installed a 6.5 fits better, looks better and has the same sound.
Old Jul 12, 2006 | 10:20 AM
SIXFOOTER's Avatar
SIXFOOTER
There is a great pattern on corvettefaq so you can put in a REAL set of 6x9s.
Old Jul 13, 2006 | 02:31 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I was able to remove the rear shade assembly and trip away some of the metal. I then reinforced it with angle bracket, etc. It looks totally stock yet has new speakers in place.
Old Jul 13, 2006 | 07:36 PM
bertmeister's Avatar
bertmeister
Boston Acoustic 6X9 (NX97) from Tweeter fit in the rear stock location and sound great.
Old Jul 13, 2006 | 07:58 PM
SizzleChest
anyone know what is supposed to be used if there is no rear speakers? i have the corner carpet pieces, but there has to be something else to keep them in place
Old Jul 13, 2006 | 08:15 PM
bams12's Avatar
bams12
I used the pattern from corvettefaq.com and the results looked real good . I was able to use a set of 4 way Pioneer and they fit with no problem.
To '79 Rear Speakers
