Tach runs backwards!
It hasn't worked since I bought the car almost two years ago. But now neddle starts about straight down ( right over the letters RPM on tach) and when engine revs to shifting speed (automatic), it will work its way backwards to about the 70 mark, as in 7000 rpms.
Anybody else ever experiense this? Is it the circuit board that it bad? I first thought that I hooked up the wire from the distributor to the filter backwards, as the plugs will allow you to do this. So I reversed it and it still does the same thing. I even bypassed the filter and still does the same thing.
Any advise? I am not looking forward to tearing apart the dash again for the circuit board to be replaced.
i just cut off the ignition, turned the needle back to 0, and turned the ignition back on, and it has worked fine ever since.
good luck
