Clutch Fork Ball Stud Length
Old Jul 12, 2006 | 11:38 AM
gnkjoy's Avatar
gnkjoy
Default Clutch Fork Ball Stud Length
My 1971 SB clutch fork ball stud is damaged and needs to be replaced. GM shows two lengths are used; 1 3/8" on 66-75 and 1 1/2" on 76-81. These are not available thru GM. Zip, Paragon, etc. only show one application and it's 1 1/2". Mine is out and it measures 1 3/8". Anyone else ran into this? Can I use the 1 1/2" stud?
Old Jul 12, 2006 | 11:55 AM
big_G's Avatar
big_G
The longer one should be fine. Usually after the flywheel is cut a few times, you would need the longer one anyways. If you want the shorter one, adjustable length one's are available thru Summit and Jegs.
Old Jul 12, 2006 | 12:35 PM
PRNDL's Avatar
PRNDL
[grandpa voice] Well kids, here is a picture posted by user Steve Straus way back in September 2001. ah yes, I remember the good old days [/grandpa voice]
To Clutch Fork Ball Stud Length
