porting a ramhorn
Old Jul 12, 2006 | 05:17 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default porting a ramhorn
how close to the corners can I get when I port my ramhorn manifold? I will post pics soon of what my magic marker says.
Old Jul 12, 2006 | 05:25 PM
mrvette's Avatar
mrvette
I may well be rong, but, when porting any airlflow device, intake or exhaust, I fail to see the advantage in matching gaskets....ME, I"d pay more attention to making sure the upstream hole is smaller than the downstream hole, and hell with the gasket....
having said that, I have allways gasket matched, even though my own sense told me not bother....
frankly, being a non split second racer anymore, and from just street feel, porting is nice, but over rated....
GENE
Old Jul 12, 2006 | 05:33 PM
Cruz59's Avatar
Cruz59
You can check out my home porting of a 2.5" set here:
http://forums.corvetteforum.com/show....php?t=1359690
Cruz59
Old Jul 12, 2006 | 05:49 PM
Guru_4_hire
Cruise-In V Veteran
GENE
well compared to other mods its essentially free....
Old Jul 12, 2006 | 05:51 PM
Guru_4_hire
Cruise-In V Veteran
Cruz59
thats really nice looking, what did you use to smooth the interior out?
Old Jul 12, 2006 | 06:21 PM
Guru_4_hire
Cruise-In V Veteran
Now with pics
Old Jul 12, 2006 | 09:29 PM
SLVRSHRK's Avatar
SLVRSHRK
Are those the ones from shop.com? I have a set in the shed and am going to eventually get to porting them out.
632C2 has done the same thing. He told me he used a Fel-Pro 1404 gasket, made it match the heads, and then used it as the template for the manifold. Are you using this technique?
I noticed that you have marker on both the manifold and the heads. If you need to take from both, wouldn't it be a little safer to port less, match the manifold and leave a littlemore meat on the manifold? I'd hate to have to do the job twice and the performance hit will probably be negligible.
Old Jul 12, 2006 | 09:36 PM
Guru_4_hire
Cruise-In V Veteran
fel-pro 1404 huh? I will have to look at that gasket and see if that requires less meat removed
thats just an off the shelf Mr. Gasket header gasket
I was going to use that opprotunity to give the entire port some love.
Old Jul 12, 2006 | 09:50 PM
Guru_4_hire
Cruise-In V Veteran
the fel-pro 1404 is a 1.5" x 1.5" gasket
the Mr. Gasket 150A that I have markered up is 1.55"x1.45"
its looking like the ideal gasket it my case is the Mr. Gasket 5900, which is 1.48"x1.45"
so that should clear up more room in the corners.
Old Jul 12, 2006 | 09:54 PM
SLVRSHRK's Avatar
SLVRSHRK
Sounds like a plan. I will have to measure my ports before selecting a gasket when I get to it.
Good Luck.
Old Jul 13, 2006 | 06:31 AM
Guru_4_hire
Cruise-In V Veteran
Good Luck.
I hope you find success with it
Old Jul 14, 2006 | 01:52 AM
Cruz59's Avatar
Cruz59
I used a air driven die grinder we have at work.
It had a long extension shaft about 1" thick, so I could reach from the 2.5" out all the way to the roundings above the mid cylinders.
I just used some coarse cartridge rolls initially and finished it up with some finer ones... Made a really good result
At the two center holes I made an angle at the top of the inlet to divert the flow a bit downwards. If you look closely you can see this at the pictures. This was done last with the fine grit rolls.
I tapped out the heat pipe first.
It must be tapped out from the top down, and inserted from bottom up.
The ends are differnt sizes!!!!
I found out the hard way as I had to re-expand the large end after driving it though the small top hole.......
If I were you I would get a set of head gaskets that fit as close to the head port size as possible. Then you match the manifolds to that, and make them a bit larger. That way you will not be so close to the edges.
With the ram horns you will not gain anything noticeable by making both the heads and manifolds larger, you will only reduce the sealing surface area.....
Happy modding...
Cruz59
Old Jul 14, 2006 | 03:16 PM
Guru_4_hire
Cruise-In V Veteran
Happy modding...
Cruz59
that is a really good point
To porting a ramhorn
