I'm trying to get loose the rusted rear leaf spring bolts. The ones that hold the spring at the wheel. the spring is lifted on a jack. The nut is rusted on the bolt! Any ideas?
(It's a 74 vette)
Heat--I push the rubber up and put a pair of vicegrips just above big washer-heat the nut and it usually spins right off---If you put a wrench at the top there is too much twist with that long bolt
You can try spraying PB Blaster on the nuts for a week or so to see if they will loosen. If the PB doesn't work you will probably either have to torch the nuts off or saw them off. I always hesitate to use flames in case there is a fuel leak that I haven't discovered. If there is a fuel leak you will probably find it pretty quickly with a torch.
