QJet Pump...does this look right?
Old Jul 13, 2006 | 11:29 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Default QJet Pump...does this look right?
Greetings,
I'm a novice with this Qjet thing, but after fighting through wrong gaskets and generic instructions from our friends at Edelbrock, I finally got this Qjet almost back together. Something does not seem right with the pump shaft...it seems to be too high. Check out the pics. Without the level attached, the plunger measures 1 1/8"above the top of the carb. In order to get the pump lever in position to insert the retaining pin, the pump shaft must be depressed about a 1/2". (Pic2)..
Is this right?
I used the new pump and spring assembly that came with the EBrock tuning kit, so the pump spring is long and stiff. With it all together and the pin inserted, it measure ~1/2". Is this right?
thanks in advance...I'm about ready to put this thing on the shelf and buy a Street Avenger...
Old Jul 14, 2006 | 01:00 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Yeah,..something is off in photo # 1. I have two q-jet cars,..both show about 3/4" exposed pump shaft.
Old Jul 14, 2006 | 08:29 AM
S489's Avatar
S489
That actually looks about right. You can do some tuning though. As the throttle is moved from idle to WOT, the accelerator linkage will travel a fixed distance. This motion is transferred to the accelerator lever tip which will also move a fixed distance along the axis of the accelerator plunger. This distance is all the travel available to work with (unless otherwise modified). Get a steel rule and measure this travel. Where the pump (seal) begins its travel is easily changed by filing or sanding the top of the accelerator plunger, just don't raise it too high (above slot) or squirt capacity is reduced. The lowest it should go is something like 3/64 (memory?) above the housing. The tip of the lever can also be bent (last) as part of getting the max squirt. There is a maximum typical plunger travel that one can obtain with a Q-jet, and a maximum (probably less) value that you can obtain with yours. Typing from memory, I've intentionally left out a lot trying to avoid too many errors. I'll come back and add numbers when I can get to them, unless someone else posts first.
PS, PM me first if you decide to get rid of it!
Old Jul 14, 2006 | 10:55 AM
BigBlockk's Avatar
BigBlockk
The second photo is correct. You're doing a good job there boy. Keep it up.
By the way, what jets and rods are you going to start with?
BigBlockk
Later.....
Old Jul 14, 2006 | 11:42 AM
kdf1986's Avatar
kdf1986
I noticed there are two holes in the pump lever. Is the rod that attaches to the lever in the right hole? If you moved it to the outside hole that would depress the plunger by about 1/4 inch, judged from looking at the photos.
kdf
Old Jul 14, 2006 | 11:46 AM
S489's Avatar
S489
it's in the correct hole for maximum travel
Old Jul 14, 2006 | 11:56 AM
CheezMoe's Avatar
CheezMoe
Hi Guy's,
thanks for the replies. The rod is in the inside hole as stated in the instructions. When it's all together it feels right and seems to have proper pump action, so when I got home tonight I'm bolting her on.
BigBlockk, I'm starting with a 74/43 combo as you and Lars had originally suggested, with float at 3/8. I hope they are really close because taking the top on and off with this choke $uck$!
Thanks again..I'll let you know how it goes this evening...
Old Jul 14, 2006 | 12:06 PM
Bob Onit's Avatar
Bob Onit
Its not that bad
Just dont hook up the choke until you get it right.
I installed studs I bought from Summit so I dont destroy the threads on my aluminum intake... makes it a 10 minute job to pull the air horn
Old Jul 14, 2006 | 05:04 PM
Rockn-Roll's Avatar
Rockn-Roll
FYI the outer hole is for CA vehicles.
To QJet Pump...does this look right?
