transmission leak continues
Old Jul 13, 2006 | 11:47 PM
spille85's Avatar
spille85
Default transmission leak continues
hey everyone, today i managed to replace my passenger mirror and in the process noticed that transmission fluid is still leaking from underneath my car. I had the car running for about 5 minutes and noticed the terrible red puddle. I took a closer look, and you could see it leaking from a metal line that runs underneath the oil pan and bends almost 90 degrees up...What are these lines....(I am not too mechanically inclined here, so please refrain from laughing too hard)...but this is where the tranny fluid is coming from ..Any input would greatly be appreciated it as always...marty
Old Jul 14, 2006 | 02:08 AM
Victor's Avatar
Victor
It sounds like these are the two hard-lines that run all the way from your transmission all the way up to your radiator. These are your transmission cooler which is built into the passenger side of your radiator. They connect to the transmission just forward of the spot where the transmission dip-stick attaches to the transmission.
Old Jul 14, 2006 | 06:26 AM
fl_rider's Avatar
fl_rider
Default Look sorta like that??
Get those fixed right away before you burn up the clutches in your transmission.
Old Jul 14, 2006 | 10:11 AM
Lee H's Avatar
Lee H
Get under there with a flash light and mirror. Often times these leak from the dip stick or kick down cable grommet and it looks like a cooling line or pan gasket leak.
To transmission leak continues
