Looking for Q-Jet tuning advice....
Old Jul 15, 2006 | 09:59 PM
69monzaredbigblock's Avatar
69monzaredbigblock
Default Looking for Q-Jet tuning advice....
I've got a relatively stock 69 L-36 with an Edelbrock #1901. I'm ready to start carb tuning using Lars' paper. I have some spare metering rods marked 36B and 48B. What is the significance of the "B" after the rod size? I'm ordering the tuning kit from Summit. Will the rods in the kit from Summit be marked "B" also? Do I want them to be marked "B"? I've heard of short taper and long taper rods, does the "B" indicate one or the other? I'm assuming I want the long taper rods. What comes in the Summit kit? Thanks in advance.
Old Jul 15, 2006 | 11:29 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I am in the process of tuning my 1901. It's a replacement for pre-1975 carb which puts it in the single or short taper category. I'm not sure what comes in the summit kit, I used an Ebrock kit which had all single taper rods. No idea what the significance of the "B" is...never seen it.
Old Jul 16, 2006 | 01:02 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
"B" means double taper,..used on pre 1975 Q-Jets.
Old Jul 16, 2006 | 07:23 AM
CheezMoe's Avatar
CheezMoe
hmm...here is the text from Lar's paper on this subject:
"There are two different “series” of primary metering rods. Q-Jets up through 1974 (the “4MV” series carbs) use the early series rods, also known as the “single taper” rods. 1975 and later Q-Jets (the “M4M” series carbs) use the second series rods, available as single taper and as “double taper” rods. Not only do the rods differ in their taper design, but they are different lengths. Pre-’75 (up through ’74) Q-Jets use metering rods that are approximately 2.47” long overall (total length from the metering tip to the extreme top of the rod). 1975 and newer Q-Jets use rods that are about 2.40” long"
I am not an expert by any means. The rods that came with my Ebrock 1901 kit measure 2 13/32" which seem to be the shorter of the two mentioned here, but there is no "B" designator on them.
Old Jul 16, 2006 | 08:40 AM
69monzaredbigblock
OK, I just came back from the Edelbrock website. It looks like I need kit #1991 for my #1901 carb. This kit comes with single taper rods for the #1901. I have some double taper rods on hand from the carb that came on the car. Can I use the double taper rods in the #1901 or should I only use the single taper rods that are in the kit from Edelbrock? Is there a preference when choosing between single and double taper in my application? Are they interchangeable? Can't find my Doug Rowe book.
By the way ,this carb has been tweaked once already and the 36B primary rods were removed and replaced with 42's. I'm not sure if the 42 rods are single or double taper. GUess I'll have to disassemble it to find out.
Old Jul 16, 2006 | 11:42 AM
Bob Onit's Avatar
Bob Onit
I just bought a set of Edelbrock #1974 rods.
They are .43 and are double taper and are for Pre 1975 (thats what the package says anyhow)
They are the exact same lenght as my 44B rods which came from my original 73 QJ
Old Jul 16, 2006 | 11:52 AM
69monzaredbigblock
The 38B rod that came out of my Edelbrock Q-jet was double tapered. It looks like the replacement rods from Edelbrock in the calibration kit are not double tapered. I'm assuming they are the correct length. I've spent the last hour at BarryK's website reading the published papers from the Masters of this tuning stuff. Right now I don't know whether to get GM parts or Edelbrock parts. Any thoughts?
Old Jul 16, 2006 | 11:28 PM
73, Dark Blue 454
Again, I've never heard of this Lars guy (and again, what book did he write?), but I have read two books from Doug Roe, who back in the day was Chief Engineer at Chevy's performance division and in his book "Rochester" on page 151 it states, "Rods with a double taper have B stamped on the rod after the taper"
Old Jul 17, 2006 | 12:28 AM
sly vette's Avatar
sly vette
"Again, I've never heard of this Lars guy (and again, what book did he write?), "
Old Jul 17, 2006 | 03:19 AM
BigBlockk's Avatar
BigBlockk
You will find many of his works under "fuel", "intake" and "tuning".
http://wiki.corvettefaq.com/index.php?title=Engine
BigBlockk
Later....
Old Jul 17, 2006 | 03:21 AM
Kalway's Avatar
Kalway
Wow... so much discussion over the the importance of something that really isn't important. All you need to do is jet based on the rods and jets. The taper isn't going to have a big enough effect for you to need to worry about. Anyone know the stock jetting of a '69 L-36? That's where you start and usually adjust from there.
Old Jul 17, 2006 | 08:38 AM
PRNDL's Avatar
PRNDL
If you can get the GM rods, I would definitely go with them. I have a 1901 and I was able to get a variety of GM rods to tune mine. Up until a few years ago I was able to order rods by part# from my local Chevy dealer. They may be discontinued now. I changed the rods/jets a couple of times and Lars changed the rod/jet combo slightly back in September when he was here in NJ.
Edelbrock uses their own numbering scheme and it is even possible that the letter "B" on the Edelbrock rods doesn't mean the same thing as a "B" on the GM rods. (edit.......Never mind, if they are stamped with a "B" they aren't Edelbrock rods!) It might, or it might not, I don't know. Unfortunately I have a very poor memory for this stuff and have to look everything up every time a question comes up!! I don't even remember which rods/jets are in the carb right now.
From Lars' carb tuning paper, 69 L-36 4spd had Qjet #7029215 which came with 71 rods 45 jets. As Kalway said, that's a good place to start.
7029215 Chev 69 396/427 MT 71 45 7036019 AX
Old Jul 18, 2006 | 11:16 AM
Bob Onit's Avatar
Bob Onit
Just to clarify
Thats 71 Jets and 45 rods
Old Jul 18, 2006 | 03:30 PM
Kalway's Avatar
Kalway
Wow a big 427 was set to run on a leaner combo than my lil 350 is. Probably works fine, though.
Old Jul 18, 2006 | 03:54 PM
olescarb's Avatar
olescarb
1968 and 1969 q-jets used smaller/different jet-rod combinations than a carb for 1970 and later (in most cases) this was because the main jet/well air bleeds are MUCH smaller than q-jets for 1970 and later. so the jet/rod package for that 7029215 is most likely not leaner than the carb you may be using, also you jet to a mixture that the engine wants not the cubic inch displacement of the engine.
henry @ oles carb
Old Jul 18, 2006 | 08:39 PM
Bob Onit's Avatar
Bob Onit
Damn, there is a LOT to learn about these carbs
To Looking for Q-Jet tuning advice....
