I Hate Por-15!!!!
Old Jul 16, 2006 | 05:02 PM
BlackRocket's Avatar
BlackRocket
Default I Hate Por-15!!!!
I recently received my awesome SR-III custom made tubular frame and it was recommended to use POR-15 on it. www.sriiimotorsports.com I diligently followed all directions and used their metal ready etching cleaner and began the application.
It was advised NOT to spray on since the vapors are extremely harmful and a pressurized mask with separate air source is required.
I carefully brushed this stuff on and did as recommended...applied a second coat when the first coat does not leave a fingerprint but the finger does not drag easily across the surface.
After putting on the second coat I noticed areas where there were drip s forming and sags. I attempted to "chase" every drip and sag but this stuff gels up quickly.
After not happy with the finish I sanded down certain areas and reapplied more POR-15. Again, the finish was not very good. I then snaded the entire frame for 5-hours in an attempt to remove all the imperfections. I tried to spray over this stuff with Rustoleum to make a smooth finish. Still after sanding for two days the finish is poor.
Now I want to remove this junk. Does anyone know if media blasting will remove it??? I tried regulat paint remover and it doesn't budge...:-(
Old Jul 16, 2006 | 05:07 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
How much is the frame worth?. It may cost you a couple of grand to get it blasted off. Is prettiness worth that much to you?
Old Jul 16, 2006 | 05:18 PM
bert21563's Avatar
bert21563
yes blasting will take it right off i did a frame i got an one side had por on it an it blast rite off live in vt. fight rust all the time por sucks!!
Old Jul 16, 2006 | 05:45 PM
Twin_Turbo's Avatar
Twin_Turbo
should have had the frame coated. The por is nice to brush on rust but not on a new frame, or a clean frame for that matter. Either epoxy or powdercoat. It won't turn milky either..por will!
Old Jul 16, 2006 | 06:00 PM
BarryK's Avatar
BarryK
WHY would you use POR15 on a brand new frame. POR15 is designed specifically to be used over rust on old parts, POR mean Paint Over Rust.
You shouldn't have runst on a brand new SR111 frame so no reason to use POR15.
i'd sandblast the entire frame to get that stuff off there, prime the frame than spray it with a good quality enamel paint and be done with it or get the frame powdercoated.
Old Jul 16, 2006 | 06:09 PM
jdmick's Avatar
jdmick
Blast it then epoxy.
Old Jul 16, 2006 | 06:20 PM
82MDVette's Avatar
82MDVette
I have used POR-15 on many parts that would not fit in my oven for powdercoating and it does sag and leave wavy lines. I guess this is what they refer to as their "Self Leveling". Otherwise, POR-15 does work great as it is advertised.
I had my frame and other large parts sandblasted and powdercoated. The frame itself was only $625 for the entire process.
Good luck!
Old Jul 16, 2006 | 11:48 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Since I did a little bit of reading on there site they offer two options. One is Prep and apply two coats DP90 epoxy black primer to frame.
The other is Powder Coating.
Sorry did not see the POR 15 info
Old Jul 17, 2006 | 01:11 AM
bondoboy's Avatar
bondoboy
We sell por 15 and I have used it. There is no reason to use it on clean steel. Using an automotive primer and paint will prevent rust as well. We have customers come in thinking this stuff is magic. It has a purpose; painting over metal that has some surface rust. I used it on my truck frame and it worked fine. The regular por will get chalky when exposed to sunlight. This stuff is not really cheaper than auto paint and it won't have as much of a shine either.
Old Jul 17, 2006 | 03:40 AM
cv67's Avatar
cv67
St. Jude Donor '05
Just because your coats sagged doesnt mean the paints bad. I did my entire chassis and underside (body) 5 years ago and it still looks brand new today.
Regular POR -Handles reflective light Ok, direct sunlight eventually it breaks down. THey make some topcoats that are UV safe and look awesome.
Didnt you post this in C4 also?
Old Jul 17, 2006 | 05:45 AM
aworks's Avatar
aworks
Have it powder coated. I did my SRIII frame that way. Way to many tubes to paint by hand or spray. POR15 will sand blast right off. The place that dose my powder coating also dose the sand blasting.
Old Jul 17, 2006 | 11:44 AM
Glassbowtie77's Avatar
Glassbowtie77
Rustoleum sells what they call their Professional Grade paint. It is available in either spray cans, quart or gallon size cans that you can either brush, roll on or put into a spray gun as well. I use the Gloss Black on mine, it is very durable and has held up really well so far. All I did was hit my frame with a wirewheel attachment on a drill and then painted right over it.
Old Jul 17, 2006 | 12:29 PM
C3 4ME's Avatar
C3 4ME
When I used to have my Z28 there was a thread on Nasty Z28.com about POR-15 vs Eastwood Rust Encapsulator and Eastwood won out big time. I used the Eastwood on an entire rear end housing for the Camaro and it came out fine. Just as mentioned, I simply brushed it on and was very happy with the results.
Old Jul 17, 2006 | 01:32 PM
rihwoods's Avatar
rihwoods
Blast it off...
Mine was sandblasted and urethane coated 13 years ago by PO...it is in great shape..no rust..vette was in Wisconsin till 1998....
Old Jul 17, 2006 | 03:36 PM
79VetteMike's Avatar
79VetteMike
I've used POR-15 with really good results except when I tried to topcoat it with Rustoleum-it would never dry and it would get kinda grainy. I topcoated with Krylon and it looks much better.
Old Feb 15, 2013 | 08:44 AM
hicswa's Avatar
hicswa
Default Keeping metal looking new
Has anyone use this product called RPM (Rust Prevention Magic) on cast iron parts to keep them from rusting? It is made by E.C.S. Automotive Concepts.
Thanks,
Danny
Old Feb 15, 2013 | 09:18 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Thanks,
Danny
http://forums.corvetteforum.com/foru...s-or-more.html
To I Hate Por-15!!!!
