Quick! Transporting an engine block
Old Sep 3, 2001 | 12:54 PM
ddn's Avatar
ddn
Default Quick! Transporting an engine block
With any luck and barring any f**k ups, I should be going to pick up my big block within the hour. How do I transport it in the back of my S-10? Ol'boy says to put it in an old tire, and then strap it in, but I'm not so sure I like that idea for traveling almost 2 hours.
Old Sep 3, 2001 | 12:58 PM
rrent's Avatar
rrent
Default Re: Quick! Transporting an engine block (ddn)
I vote with the Ol'boys - tire will keep it from rolling around. Of course if you are going to strap it down, it could just as easily ride on a couple of well placed 2X4's...
Good luck, by the way if you don't strap it at all - just DON'T HIT THE BRAKES
Old Sep 3, 2001 | 03:33 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Quick! Transporting an engine block (rrent)
I moved a small block using a tire and two straps.
Set the tire under the oil pan, or more like the oil pan in the tire.
The motor I was moving had the original mounting hooks on it still, so I ran a ratchet strap from each of these to the hold down hooks in the truck.
Good luck -- have fun with the new motor.
Old Sep 3, 2001 | 03:43 PM
roger68's Avatar
roger68
Default Re: Quick! Transporting an engine block (BSeery)
An old tire will work, plus you may want to block it here and there to get it fairly stable. I would darn sure not use anything less than four good, strong staps - one towards each corner of the bed. I was hauling a 396 in an old El Camino, went around a corner here in good old AZ, then spotted 3 or 4 cows right in front of me - had to hit the brakes hard from about 50 mph. Had I not used 4 tight straps to hold that engine in place, I might still have knots on my head from getting smacked by a BBC.
Roger
Old Sep 4, 2001 | 12:40 AM
ddn's Avatar
ddn
Default Re: Quick! Transporting an engine block (roger68)
All went well. Moved it with a tire and 4 tie-downs, one to each corner. Figured it all out myself ;)
More info later
To Quick! Transporting an engine block
