78 valve cover
Old Jul 17, 2006 | 07:42 PM
Billiter72's Avatar
Billiter72
Cruising
Default 78 valve cover
I switched the stock air cleaner on my 78 to an open filter. All I want to do is put a breather on the passenger side valve cover...it should be simple. The stock breather (metal tube) is on there solid. Is it bolted from the inside of the valve cover - do I need to remove the valve cover to remove it? Seems like too much work for such a small application.
Old Jul 17, 2006 | 08:13 PM
1Z87L8's Avatar
1Z87L8
no bolts but dried out rubber, same problem i had.
you have to pull out on it really hard while working it back and forth (no perverted comments needed)
i ended up replacing the rubber grommet in the cover found it in the help section at autozone also be aware that the breather needed is 3/4 if i remember right not the 1" it is way too big for stock valve covers.
good luck
Old Jul 17, 2006 | 08:28 PM
Billiter72's Avatar
Billiter72
Cruising
With the old rubber gromet, do you think I'll get dried pieces dropping into the motor as I try to break it loose? Or will that even hurt anything
Old Jul 17, 2006 | 09:30 PM
...Roger...'s Avatar
...Roger...
Should be contained in inner baffle--reach inside and pullit out
To 78 valve cover
