Any danger after cam breaking?
Old Jul 19, 2006 | 12:55 PM
ImBatman's Avatar
ImBatman
Default Any danger after cam breaking?
Does the danger still exist for wiping a lobe after a successfull cam break in even if you continue using higher zinc content oil? Was wandering this because I had a battery die on me last night while trying to crank a flooded engine. Turned out to be a bad o-ring on the needle and seat so I quit trying till I get a new one today.
Old Jul 19, 2006 | 09:34 PM
jerrylee's Avatar
jerrylee
I'm by no means an expert but I'm going through the same thing so I called comp n the tech. said If there is going to be a problem it will be during the initial break-in...after that you are in the clear....Also Castrol told me that as long as the cam is properly lubed the oil should not be a factor during cam n lifter break-in..they also stated that even though zinc n phosphorous levels have deminished they are still at levels that will provide ample engine protection.......Who knows...
Old Jul 19, 2006 | 10:47 PM
mandm1200's Avatar
mandm1200
Things you probably alreday know. A lot of wear occurs when an engine is first fired up. New Parts are mating with other new parts for the first time. Break in additives help reduce rapid wear as these parts come to together. Cam lobe failure may not show up right away. It seems that those who wipe a lobe have an issue several thousand miles down the road. Manufactures know how to break an engine in. If not, they would be doing a lot of warranty work. As long as you followed customary procedures I would not be too concerned. I changed oil after about 10 miles on the engine. Cut the filter apart and looked at it to see if anything jumped out. I added another 8 ounces of the GM EOS and will change the oil after about 500 miles. I feel at that point the engine should be good to go and will run run regular dino oil for another 1000 miles. I am planning on switching to Moble 1 after that.
I had a 78 Chevy that had a wipe camafter about 50k miles. Not sure why?
Old Jul 19, 2006 | 10:54 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the cam break in period teaches the lifters to spin on the cam lobes....so as long as there are no other problems such as lifter bores that are screwed up, you may be ok....the failure shows up down the road because thats when the culmulative effect finally catches up....i say don't worry about and use a high zinc oil such as valvoline racing oil and forget about it, until a problem surfaces
Old Jul 19, 2006 | 11:02 PM
MsVetteMan's Avatar
MsVetteMan
Drive it, like you stole it!!
Old Jul 20, 2006 | 08:02 AM
ImBatman's Avatar
ImBatman
Thanks guys!!!!
Old Jul 20, 2006 | 11:24 PM
Sayfoo's Avatar
Sayfoo
Personally, I'm totally confused. Seems like the whole issue traces back to Hot Rod magazine and Comp cams? It does appear that modern oils are reducing their zink contents to protect catalitic converters. Are oil companies adding other, non harmfull to cat converter, additives? I would think so. Is zink the best? Or is it just the cheapest? Or both? Do other additives work as well, but are more costly, so that the oil companies did not use them in the past?
Yes, it does appear that there are alot of cam failures recently. But is it totally because of the oil? There have been alot more radically ground, high spring pressue cams installed recently then ever before. Also, cam metal or heat treat quality could be suspect. Check out the Amsoil web site. They state that too much zink will cause heavy valve deposits. How much is too much? There was a previous thread that listed additive content of numerous oil brands. Obviously, they were all different. Were the low zink oils "bad". Or did they compensate with other additives? Common belief is that most aftermarket additives won't harm a engine, but where do you stop? Sounds like this issue will go on and on for along time. I'm confused.
Old Jul 21, 2006 | 12:11 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Those are some really good questions.
Though the new API SM/ILSAC GF-4 standards have higher performance standards than older standards, they actually severely restrict ZDDP additives (by limiting phosphorus to 0.08%). This was done at the behest of the automotive industry to help them meet EPA requirements, not protect the engine.
You can read the ILSAC GF-4 standards here:
http://www.ilma.org/resources/ilsac_finalstd011404.pdf
You can see the EPAs impact on the auto industry in this letter:
http://www.ilma.org/resources/gf4letter.pdf
And you can read the history, including the why the auto industry and the EPA wanted the new standard here:
http://www.northamericanlubricants.c...s/gf4specs.htm
Some oil companies have added other anti-wear additives to offset the loss of the ZDDP, but they aren't exactly forthright in what. I've read, but can't confirm that AMSOIL, particularly for the AMSOIL Series 2000 0w30, has raised the level of ester in their oils to help offset the loss of the ZDDP. This appears to have raised the cost as you suspected.
As an alternative, diesel oils do not have the same phophorus limitations of API SM automotive oils, and for those that desire to use a synthetic 5w30 with higher levels of anti-wear additives, I suggest the AMSOIL Series 3000 Synthetic 5w30 Heavy Duty Diesel Oil.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jul 21, 2006 | 11:52 AM
bobs77vet's Avatar
bobs77vet
why be confused? go with a name brand oil and buy one for its intended purpose....for example i have a modified engine and use valvoline racing oil.....i let valvoline put in the right additives compared to me doing some mr jeykl and Dr hyde mixing of additives in my garage..
Old Jul 21, 2006 | 01:09 PM
mandm1200's Avatar
mandm1200
Is that the oil Vavoline recommended? If not, then whats the difference with adding additives or guessing which oil to purchase? Either way its a crap shoot.
Old Jul 21, 2006 | 02:57 PM
jerrylee's Avatar
jerrylee
I tend to agree n there's a informative site at--[offroaders.com/tech/snake-oil.htm]--which I think tends to raise a few questions n makes you think alot of this is just pure sales pitch....what do you guys think....Jerrylee///
Old Jul 21, 2006 | 03:42 PM
Meh's Avatar
Meh
My parents had a 77 with a 305 that wiped a lobe after quite a few miles, fixed it, same thing happened after some time. Swapped in a 350 and never had to deal with it again. Was yours a 305? Seems a little fishy...
Old Jul 21, 2006 | 04:01 PM
bobs77vet's Avatar
bobs77vet
well its the oil vavoline sells for racing motor applications....and since i'm not using any cats i'm not worried about contaminating them.
whats the difference, engineers with degrees are designing the oils as opposed to us looking at marketing hype and trying to make decisions.......so perhaps it is a crap shoot either way, but i like to find the oil closest to my intended use made by a name brand manufacturer and i purchase that. You can go crazy looking at this stuff trying to decide what is correct to buy...too much of this, too little of that, it will drive you nuts trying to figure out if its the right stuff or not
Old Jul 21, 2006 | 04:59 PM
mandm1200's Avatar
mandm1200
Mine was a 350. I heard that chevy had some 'soft' cams in that period of time.
Bob:
I'm not saying the oil you choose is incorrect. Manufactures make oils for different applications. One is better for one application while another is better suited for another application. A slightly modified engine running 99%-100% of its time on the street might be better off with one of Valvoline's street oils. These large oil companies should have the knowledge to determine which of their products would work better for a street engine. Race engines under race conditions may only see several hunderd miles of use before being rebuilt or refreshed.
What oil is the best? What additives are the best? I wish I knew.
Old Jul 21, 2006 | 05:45 PM
bobs77vet's Avatar
bobs77vet
........One is better for one application while another is better suited for another application. ...........
i agree ,almost too many choices
Old Jul 21, 2006 | 10:03 PM
Sayfoo's Avatar
Sayfoo
Surprise, surprise, I actually agree with you, but you missed the point. "Confused" was a sarcastic attempt at humor. The point is, most of us really don't KNOW that low zink oils are bad. We don't really KNOW that low zink oil is the major cause of cam failures. We may suspect it, and some cam companies may say it, but we don't really KNOW it. We don't KNOW that replacement chemicals are just as good or better or not, or if the all mighty dollar dictated what they used in the past. I tend to think that modern science can make a additive package that will work well, and meet gov't and auto co. directives. Remember Slick 50?? Many people swore it was the absolute best, used it in everything, but the company had to retract their advertizing claims and pay a hefty fine. And they still sell it. So, yea, reasearch what you can, and stick with a major brand of oil.
Old Jul 21, 2006 | 10:16 PM
bobs77vet's Avatar
bobs77vet
you know the bottom line is all you can do is as time allows....research stuff, think about it, have a healthy dose of skepticism and then make a decision and move on to the next choice..... right or wrong, i'm always telling my kids "its all about time" we just don't have the time to become experts in everything.
To Any danger after cam breaking?
Old Jul 21, 2006 | 10:27 PM
bobs77vet's Avatar
bobs77vet
check this out its what i use in the 10w 30 weight
http://www.valvoline.com/pages/produ...asp?product=50
Old Jul 22, 2006 | 12:25 AM
marshrat99's Avatar
marshrat99
Bro's and Sis's, this debate will go on for centuries. Me thinks that if you change oil regularily (3K-4K) then this is not an issue. My opinion is that you should use a good oil (all name brands meet the API specs) and change/check regularily. Why spend good money if'n you don't got to?
Old Jul 22, 2006 | 11:54 AM
mandm1200's Avatar
mandm1200
This type of thread comes up every couple of weeks. All the major oil companies sell the best oil, or at least that's what they advertise.
What I find ironic is that some of these same companies, including Valvoline, sell oil additives. If their oil is so great, why do they sell additives?
